print list class
blimey
quote:
Originally posted by Mechanix:
i went to the web site below and cut & pasted the list class utility. how do i get it to work?
This was posted in the general discussion and I'd like very much to be able to use that tool. So i've tried to make a script with the txt file provided, it worked fine and compiled succesfully. Then I don't know how to use the tool. I expected it to output a text file with the classes, but do not know how to run it or were it saves the file... Can someone help me?
Thanks
  • 1 month later...
  • 2 weeks later...
This will allow you to place the file somewhere sensible:
PROCEDURE ClassListOut;
VAR
counter, countClasses : INTEGER;
outputfile : STRING;
BEGIN
PUTFILE('Export Class List','Class List',outputfile);
countClasses:=CLASSNUM;
IF (countClasses>2) THEN BEGIN
counter:=0;
REWRITE(outputfile);
REPEAT
WRITELN(CLASSLIST(counter));
counter:=counter+1;
UNTIL (counter>countClasses);
CLOSE(outputfile);
END;
END;
RUN(ClassListOut);
  • 3 years later...
Steven,
there is a sub-routine in Vectorlab which does what you need. You must open/close the file elsewhere, but there is an example which is running as stand-alone script. I believe you'd prefer this.
Export class attributes is Subroutine for exporting class attributes as TAB file
I didn't try it in a while, but it should work. Since is old, it might fail on custom markers.
