Rick Francken Posted October 21, 2005 Share Posted October 21, 2005 Is there a Vectorscript function for the "Section Solids..." menu command? I have found the corresponding Vectorscript functions for "Add Solids", "Subtract Solids", and "Intersect Solids", but have not found one for "Section Solids". Does it exist? I observed that when you Export Vectorscript, if there is a solid section object in the document, the Vectorscript file is corrupted and cannot be re-imported. The pattern appears to go like this: for an Added Solid, Intersected Solid, or Subtracted Solid... var tempHandle, tempHandle1, tempHandle2: handle; result: integer; result:= AddSolid(tempHandle, tempHandle1, tempHandle2); result:= SubtractSolid(tempHandle, tempHandle1, tempHandle2); result:= IntersectSolid(tempHandle, tempHandle1, tempHandle2); For Section Solid I would expect the same thing... result:= SectionSolid(tempHandle, tempHandle1, tempHandle2); Instead the line is written like this: tempHandle, tempHandle1, tempHandle2); Is there a way around this issue using Vectorscript? -Rick Francken Quote Link to comment
