How much data can you attach to a wall...and export it via IFC4?
shorter
Not a trick question or part of my questionnaire...
If you have a wall, with components, how much data can you attach to the wall and it's constituent components?
If the wall style is given the type mark 'IWS-100' for example, and the wall comprises
Paint
Skim Coat
12.5mm Plasterboard
12.5mm Plasterboard
Timber Stud with Insulation
Airgap with split battens
Timber Cladding
Sealant
how much data can be assigned to each component and more importantly, exported via IFC?
I realise the above is nonsense, because who models paint, but lets say a client has asked for paint to be modelled, how would you give the paint component a unique ID that relates to it's location (floor and space), and give it a type mark 'PNT-100', and export to IFC with Uniclass classification 'Pr_35_31_22_37'?
Hello @shorter
Technically the IFC-Schema allows you to attach an unlimited amount of Data to Entities.
To get an IfcWall aggregated from IfcBuildingElementParts, you should set the 'ExportOptions - by Components' in the Datamanager.
This will give you a comparable IFC-structure to Vectorworks. (Wall with Components = IfcWall with IfcBuildingElementParts)
You can then use the usual Datamanager-workflow to add an map data to each Entity.
Component-Data can be querried through worksheet functions.
Components carry limited Data, custom Records cant be added directly to components.
The Material Ressource allows for a lot of Data to be added to it, including custom records.
Materialdata can then be querried and mapped for each component in the Datamanager.
All of this Data can of course be exported to IFC - you just need the corresponding worksheet function to query it.
The classificiation is a bit of a tricky question - it depends on how you set up your classificiation workflow and the system you use.
I am not familiar with the Uniclass System - answer depends on the logic of the classificiation system - there are multiple ways how to go about this.
Greetings from Germany
Viktor
As I understand, doing so, i.e. exporting by component, does not export the wall itself.
Anyway, I can see one specific problem...
"custom Records cant be added directly to components."
Since the client, and almost every client we have come across working on project in German, and Switzerland, requests custom psets and for all wall and floor coverings to be exported with data present in the custom pset.
Hello @shorter
No, of course the wall is still exported.
With the Option named above you get a IfcWall Entity and multiple IfcBuildingElementPart Entities(one per component) in your Ifc-File.
They are related through IfcRelAggregates which is a general composition/decomposition (or whole/part) relationship.
These Entities can then be individually adressed in the Datamanager. So you can add Psets as you wish to the Entity you wish.
I am talking about the vectorworks resource "record format" here.
You can query component Data and Materialdata of components with the corresponding worksheet functions and map that data to you desired IfcPsets.
Yeah - no problem thats easily with the normal Datamanager workflow ?
I dont see the issue here ?
Viktor
3 minutes ago, Viktor Frank said:
Hello @shorter
Viktor
Ah, it must have been something Mihail showed me that resulted in the wall not being exported, but the components were.  A different solution, perhaps.
Still what you have demonstrated is that this is not a 'normal' nor simple process and one that requires significant knowledge and experience of the use of the data manager and ifc; something that will escape many, particular since this topic is obfuscated in the help system.
No entry for 'IfcRelAggregates' for example.
Where would us mere mortals look for such illumination?
Hello @shorter
29 minutes ago, shorter said:
....requires significant knowledge and experience of the use of the data manager and ifc....
Very true .... the IFC-Schema alone is huge and takes quite a while to wrap your head around it.
IMO one specialist is necessary per party to guide the whole process.
Relations are generally not shown in the Datamanager ... they are always created in the background.
Well, in the DACH-Region we create Webinars for our customers that specially target these topics.
For example we have a 3 x 1 hour Datamanager Webinars that give an overview.
Additionally we offer consulting services for offices that want to dive even deeper.
Some other questions are solved at the helpdesk or in the DACH-Forum.
Greetings
Viktor
  • 1 month later...
Paint
Skim Coat
12.5mm Plasterboard
12.5mm Plasterboard
Timber Cladding
Sealant
To further complicate things, I am trying to do this in Vectorworks 2024...
If I use the condition
=IF(OBJECTDATA('Component', 'Function', T=INDEX)='Load-Bearing', 'IfcWallStandardCase', IF(OBJECTDATA('Component', 'Function', T=INDEX)='Inner Finish', 'IfcCovering', IF(OBJECTDATA('Component', 'Function', T=INDEX)='Outer Finish', 'IfcCovering', IF(OBJECTDATA('Component', 'Function', T=INDEX)='OTHER', 'IfcBuildingElementProxy', 'NoExport'))))
the wall is converted to an IfcCovering and does not export as IfcWall at all.
Think it may be time to delete preferences and start again?
using a condition
=IF(OBJECTDATA('Component', 'Function', T=INDEX)='Load-Bearing', 'IfcBuildingElementPart', IF(OBJECTDATA('Component', 'Function', T=INDEX)='Inner Finish', 'IfcBuildingElementPart', IF(OBJECTDATA('Component', 'Function', T=INDEX)='Outer Finish', 'IfcBuildingElementPart', IF(OBJECTDATA('Component', 'Function', T=INDEX)='Insulation', 'IfcBuildingElementPart', 'NoExport'))))
fails.
All components export as IfcWall.
If I got that right, that is no more supported in newer IFC versions above 2x3 ...
Don't know anymore on which forum I read over a few threads about it VW DE, Bricscad, ... (?)
Maybe because of the Voids for Wall Openings (?).
(Although you could attach a single Void to multiple Objects in IFC)
But you could ask also here, they know everything about IFC
It's been a while since I exported IFC from VW - in this sense.
Maybe it was Bricscad where users had problems getting their Wall components into Twinmotion and it was said that you could not get the Components out, just the overall Wall.
I also think to remember that I had access to Component geometry from IFCs in the past. By VW ? By IFC 2x3+ ?
But if it works for you in VW 2025 .....
Looks like my VW IFC 2x3 exports with separated components option :
- Only exported singly-Ply Walls as IfcWall
- All multi-Ply Wall's Components came as separate IfcBuildingElementPart
- So there is no IfcWall representation for any multi-Ply Wall's
In IFC 4.0 I can not see differences so far between VW 2025 and VW 2026.
Here for VW 2026
- All multi-Ply Walls are IfcWall only (no aggregates or such)
- Components are accessible in Bonsai IFC Item or IFC Edit Mode (Or Blender Edit Mode)
- IfcTypeProduct Infos available
- IfcSurfaceStyles (VW Render Materials) seem to be not correctly assigned
- (not sure about the VW Building Materials Assignments, but their definitions came in)
Edited by zoomer
