Stephan Sonnenschein
Get Handle to closest Object
Starting with the location of one selected CustomObject I want to get a handle to another CustomObject which is close to this object and do something with that object. Imagine to a for instance a Pipe System where I bring to objects close to each other (via underlying grid). After they are positioned this way they should interact with their neighbour (change some RecordFields).
I thought GetClosestPt() would be the right approach but when I tested the example from the function refence I didn't get any reaction when I clicked (=GetPt()) near a simple rect. Also the Debugger shows that no objhandle is identified.
1) Does anybody know how to use this function correctly?
PROCEDURE GetClosestPtExample;
VAR
obj :HANDLE;
ptX, ptY :REAL;
index :INTEGER;
containedObj :LONGINT;
BEGIN
{$Debug}
GetPt(ptX, ptY);
GetClosestPt(obj, ptX, ptY, index, containedObj);
SetPenFore(obj, 65535, 0, 0);
END;
RUN(GetClosestPtExample);
2) If this function doesn't work. Has anybody an alternative solution for my problem?
Try sending the parent object to the back first then select closest point. I have also been trying something similar to this but it gets tricky when both PIO's use the same code - therefore when one finds it's child object the child object becomes the parent and thus finds the original parent (confusing i know) what needs to be done in this case is somehow setting a flag on each object (like an invisible field) to say that it's been done. Please let me know if this helps, it might help my tool along.
