2026 texture application Perimeter and Surface UV
gplumb
Testing 2026 for our company rollout. i have come across a texturing issue.
Create and apply a texture, change the map type from Surface UV to Perimeter will cause an immediate crash
Perimeter to Surface UV the same
Plane to Surface UV or Perimeter the same
This happens with or without images used in the texture.
3 answers to this question
I little bit of follow up
In order to check if the issue is about my original 2026 installation, i installed again on a spare laptop (Which is also Mac OS 15.5).
base install, no preference or plugin changes - Blank (Metric). Same outcome - instant crash while changing texture map type.
