jeff Posted December 3, 2002 Share Posted December 3, 2002 I am working in the theater, and Vectorworks quits when I go to print; it does not get as far as the print window. Indeed, it now quits spontaneously and without any provocation. Restarting does not solve the problem. I am away from home in-theater, and don't have my disks to reinstall or my registration code to run under OS9. I do have high speed internet access. Please advise. I am running a Powerbook G4 667, 768mb RAM, OS 10.2.2. Thanks in advance. Quote Link to comment
Guest Posted December 23, 2002 Share Posted December 23, 2002 What version of VW are you using? What printer are you using? You can use the same application under OS 9 - by two ways. You can set the program to launch in classic mode by doing a Cmd I on the application. Checkmark "Launch in Clasic". Or you can move the application to the root of the hard drive and just create a shortcut on your dekstop for OS 9 to launch it. You don't need to have it installed twice on one computer to have it launch in OS 9 or 10. I keep everything at the root since I am constantly booting between OS 9 and 10. I only keep one copy of everything. Quote Link to comment
