Festoons
DianaK
This was requested by a production electrician so I would imagine she wanted to function like a fixture that shows a likely swag and can be drawn like a poly line with a line type or similar. I used to just drop the symbol, scale it (ugly) and then call it a light so it worked in light right.
If you’re wanting to estimate the end heights and sag of the cable, there is also the third-party Catenary Curve plug-in. No lighting as part of the plug-in, so you’d have to add those separately.
Edited by rDesign
  • Like 3
What I've done is use the Festoon Marionette for the Plot and 3D views, then created a simple symbol as a "lighting fixture" to attach the Label legend to and for worksheets/Lightwright. On the plot it looks like so:
  • Like 3
Hello,
In tech support last week I had an LD who wanted to number and label the different types of bulbs and also the length of the catenary. Using the Marionette tool as mentioned above, once they were happy with the result I got them to Modify>Convert to Group and then ungroup. Once done just add the EntEquipUniversal record (or Light Info if required) so the Numbering command auto numbers the lot. I then created a quick Data Tag and a Graphic Legend. In the enclosed file it was using the symbol name which as you can see was too long and should be shortened.
Festoon v2026.vwx
Cheers,
Peter
On 9/30/2025 at 10:27 PM, grant_PD said:
there is a plug in tool that does this.  I had it for a while.  search "festoon" in the message board and it may come up.  I recall that I also used the rope and stanchion tool to get the swag, and then duplicated a symbol along it for the lighting festoon.
No luck on search, but sounds cool
  • 3 months later...
