wjb Posted June 30, 2005 Share Posted June 30, 2005 Can anyone give me direction on how to write a script to create a useable graphic representing rigid insulation? Quote Link to comment
Delmer Posted June 30, 2005 Share Posted June 30, 2005 Have you looked through the hatches provided? Check for a hatches file in the extras folder. Quote Link to comment
mike m oz Posted July 1, 2005 Share Posted July 1, 2005 The standard insulation tool slows the drawing file down substantially because of all the curves. A simple zig zag line in lieu of this would suffice for most drawings. The insulation tool could then be used for details only. [ 07-01-2005, 10:30 AM: Message edited by: mike m oz ] Quote Link to comment
Delmer Posted July 1, 2005 Share Posted July 1, 2005 Mike aren't you talking about batt insulation though? I think the hatches labelled rigid that come with the program use a vertical line pattern -I'm not sure where that is the standard. The one I use is closer to a tight 'Tile Stack Bond'. Quote Link to comment
Species 8472 Posted July 4, 2005 Share Posted July 4, 2005 That's not really what we're looking for. We're trying to write a script that produces Rigid Insulation, in the same way the Batt Insulation plug-in tool produices batt insulation. We've managed to get the plug-in to give the first two lines for Rigid, but we're having trouble figuring out how to write the script to get in to repeat. Quote Link to comment
Species 8472 Posted July 27, 2005 Share Posted July 27, 2005 Anyone? anyone at all? or is this beyond the collective power of VW users? Quote Link to comment
jan15 Posted July 27, 2005 Share Posted July 27, 2005 It's beyond our collective power to understand what you're talking about. On Earth we represent rigid insulation in various ways, but none that would involve the use of a VectorScript. Quote Link to comment
arthur&l?on Posted August 2, 2005 Share Posted August 2, 2005 Hello I have written an insulation tool and it's at the vectordepot. This tool has now new features and has 3 rigid modes. It will be part of a whole set of archi tools available as soon as possible. If you have questions, just mail me. Regards Francesco Quote Link to comment
Species 8472 Posted August 2, 2005 Share Posted August 2, 2005 Thanks. Can't find it there though, i may be just missing it. what's it called? is it in the plug-ins directory? Quote Link to comment
wjb Posted August 2, 2005 Author Share Posted August 2, 2005 Thanks to those who've replied to my original post. Particular thanks to Francesco / arthur&leon who seem to be on the right track. Now, if I could only find that link... Quote Link to comment
jan15 Posted August 3, 2005 Share Posted August 3, 2005 I found the link. It's on page http://www.vectordepot.com/PlugIns1.shtml and it's labelled: "Insulation/Isolation PIO This draws batt insulation/isolation in a different style than the standard NNA PIO. Contributor: Francesco Bellasecca Version: VW 9.0" It appears to be an update to version 9 of Frank Schnater's "Insulation Tools" found on the same page. It consists of two tools. One, called "isolatie zacht", draws ordinary batt insulation. The other, called "isolatie hard", draws zig-zag lines such as were commonly used in the days of hand drafting to poche metal stud walls on plan, but which I've never seen used in any CAD drawings. Quote Link to comment
Species 8472 Posted August 4, 2005 Share Posted August 4, 2005 well i suppose it does what it's supposed to do, but still doesn't achieve what we're looking for. so my original question still stands - HOW do i write a vectorscript for rigid insulation? if it can be done for batt, which has curves and angles, then rigid should be easy - just offset lines. Are there any vectorscript writting resources out there anywhere? Quote Link to comment
jan15 Posted August 4, 2005 Share Posted August 4, 2005 quote: Originally posted by Species 8472: ...rigid should be easy - just offset lines... Aha! A clue! But still not enough. We'd like to help, Species, but we can't read minds. This topic has been up since June, you've found only two other people who believe there's a standard way to represent rigid insulation, and now it seems at least one of them disagrees with you about what that standard is. If you could see your way clear to describe it to us, we'd promise not to tell anyone else. And it may be that someone has already written the script you're looking for. Maybe he just doesn't know it's rigid insulation. Maybe he thinks it's the standard way to show monorail tracks. As far as vectorscript writing resources, there's the VectorScript Language Guide and the Function Reference. Do you have those? Both available for free download at http://www.nemetschek.net/support/custom/vscript/docs.html [ 08-04-2005, 08:13 PM: Message edited by: jan15 ] Quote Link to comment
wjb Posted August 5, 2005 Author Share Posted August 5, 2005 With apologies to all those who tried to help, perhaps we assumed incorrectly that there was a standard graphic used to illustrate rigid insulation. In Canada, rigid insulation is typically drawn by a rectangle of dimensions equal to the insulation material thickness and length in section, filled with a repeating pattern of short lines (perpendicular to the long axis) which are 2/3rds the width of the rectangle, alternating in direction, and staggered equally along the length of the section. Quote Link to comment
Species 8472 Posted August 5, 2005 Share Posted August 5, 2005 __________________________ | | | | | | | | | | | | | | | | | | | | ----------------------- best i could do with ANSI graphics. Quote Link to comment
Species 8472 Posted August 5, 2005 Share Posted August 5, 2005 sorry, didn't work Quote Link to comment
arthur&l?on Posted August 5, 2005 Share Posted August 5, 2005 Hello all Maybe my english is bad. Sorry. As you've noticed, there's an insulation tool of mine on the vectordepot...and it's not an upgrade of somebody's else. This version hasn't a 'rigid' mode. Here's a link for an enhanced pio with a 'rigid mode' button. It's surely not a standard design, but here in Belgium builders understand it. www.archFB.be/0000-ISO01.vso Regards Quote Link to comment
Species 8472 Posted August 5, 2005 Share Posted August 5, 2005 Thanks, i found that one. doesn't give us what we want, so i'm attempting to re-write the code to produce our desired result. Difficult, though, because trying to read the guides and references are about as difficult as writing the script itself. Thanks to everybody for trying. Quote Link to comment
wjb Posted August 5, 2005 Author Share Posted August 5, 2005 PLEASE IGNORE THE ABOVE GRAPHIC - WHAT WE ARE LOOKING FOR IS MORE LIKE THIS: ------------------------------------------------- | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ------------------------------------------------- Quote Link to comment
jan15 Posted August 5, 2005 Share Posted August 5, 2005 Like this? My apologies to Francesco. I must have downloaded Frank Schnater's insulation plug-in a second time when trying to download yours. Now I've got the right one, and a very nice PIO it is, creating a batt insulation symbol which doesn't have to be solid filled. And certainly there's no problem with your English. I would never have guessed it wasn't your first language. [ 08-06-2005, 12:07 AM: Message edited by: jan15 ] Quote Link to comment
wjb Posted August 5, 2005 Author Share Posted August 5, 2005 Exactly. Now, can anyone replicate this through a script? Quote Link to comment
jan15 Posted August 5, 2005 Share Posted August 5, 2005 That's a unique and attractive hatch pattern. It would have been too slow to use in hand drafting, but now with CAD we should be using it for something. Here's what Francesco's Belgian version looks like: Also very distinctive, and it would be easy to guess that it represents rigid insulation. I'm going to try to find use for both of these. Quote Link to comment
arthur&l?on Posted August 6, 2005 Share Posted August 6, 2005 Don't apologize and thanks for your comments, jan(15). To Wjb and Species : this pattern is easy to script, why dont you use my Iso code as a starting point ? Regards Francesco Quote Link to comment
Species 8472 Posted August 8, 2005 Share Posted August 8, 2005 that's what I'm going to try - just a matter of getting in and playing with it. Thanks for providing a starting point! Quote Link to comment
Ryan McCuaig Posted October 26, 2005 Share Posted October 26, 2005 quote: Originally posted by wjb: In Canada, rigid insulation is typically drawn by a rectangle of dimensions equal to the insulation material thickness and length in section, filled with a repeating pattern of short lines (perpendicular to the long axis) which are 2/3rds the width of the rectangle, alternating in direction, and staggered equally along the length of the section. I've made up a linear plug-in that does the "Canadian standard" version as well as the one shown in Detail magazine: Unlocked, fully probe-able. Share it to your heart's content. Hope this helps. Quote Link to comment
