Dubman Posted September 25, 2025 Share Posted September 25, 2025 I'm rebuilding VW 2026 like suggested instead migrating my 2025 settings & trying to remake my Custom Tools. In both 2025 & 2026 after running the script to use a certain class, constraint,& tool, it is not leaving the class to where I was when using the custom tool. In 2024 it does like I have always used them. Anyone else having this happen? Another Custom Tool question, in the tutorials to create one says to selected the Class, Tool, Constraint, Pen thickness-type-color. With the class already being set for Pen type, thickness, & color; why do you need to set these when creating the Custom Tool? Quote Link to comment
Dubman Posted October 2, 2025 Author Share Posted October 2, 2025 UPDATE in the effort to keep trying things to see if there is a work-around, I've noticed the active class selected is not displayed correctly between the ribbon across the top & the Navigation pallet. When changing the active class in the ribbon above it does not change in the Navigation pallet. Quote Link to comment
Pat Stanford Posted October 3, 2025 Share Posted October 3, 2025 I just tried it on a Mac and changing the active class in either location changed it in both locations. What happens if you try one of the default workspaces? Or Restart VW? Quote Link to comment
