Hello Community! Our community board will be offline for maintenance as we perform an upgrade from June 8th at 8:30 am ET until June 9th. We appreciate your patience and understanding during this time.
Handling Referenced Images with Marionette
Chris Busch
Hi!  I'm trying to batch rename and relink a large set of referenced images in a vectorworks file.  We do the same basic interior layouts with accompanying images placed directly on the design layer, but they change slightly with each project cycle.  Because they're referenced objects, it doesn't appear to work with the Batch Rename function, and even if it did I don't think it would address the linked file path.
Essentially, I'm trying to run a marionette network or script to change a reference path from
C://User/Documents/Projects 2024/SampleImage_1_2024.jpg to
C://User/Documents/Projects 2025/SampleImage_1_2025.jpg
and have it relink the new image from the new file path.  Is this possible?  Thank you for your help!
-Chris
