PIO to send "keystokes"
LarryAZ
First I have very little knowledge of VS but I want to learn. I tried to buy the manual but was told NNA doesn't sell it. I find it had to learn using the pdf manual but I'm working on it.
My question is can I write a PIO that will send keystrokes to execute a menu command. I like using single keystrokes for commands and want to be able to press "v" to execute "class visablilities" as an example. VW will not let me use the "v" without a modifier in the menu commands but it will to select a PIO. If a custom PIO named class visibilities would send the keystokes to execute that command and then deselect it's self I would have my single keystroke command to anything I want.
Is this good or flawed logic?
Thanks for the help.
