justin1974
Text Size
Simple request yet can't get to work.
I have a simple Grid line marker.
Graphically it consists of a circle with a bit of text eg: "x1"
I'm using a pop up menu for scale; 5,10,25,50,100,200. to adjust the size of the circle and the text. The idea is that I can work on my building sections at layer scale of 10 to see the details, while using a viewport of scale 1-50. to print sections.
Hence PIO will controll the correct scale apearance of the Grid Buble for the viewport independent of the scale of drawing.
I have no problem in scaling the circle however I can't get the text to stay constant. When I insert the PIO on layers of different scales the text size changes in relation to the circle size.
Im using
settextsize(lnewobj,0,5,2mm*scale);
I'm guessing that settextsize references the layer the object is on to figure out how big 2mm is.
Any one know a way arround this?.
I dug up a sample plug-in object script that I wrote a couple years ago that does something similar to what you want. This script is for a linear plug-in object the has the following parameters:
code:
LineLength Line Length 1
Factor Number 1
Title Text Integer 14
Title Text Your Title Here
Scale Boolean TRUE
Scale Text Integer 12
[/code]
The "Scale" parameter was just used to force a regen (reset) of the object for testing purposes. You won't need that. Also, if you go to the Properties dialog when creating your plug-in object, you can turn on the "Reset on Move" flag. This will force a reset when you paste the object onto a different layer. ( A paste is considered a Move.) I think there is a bug in that "Paste In Place" doesn't cause the reset, but we'll fix that in next version.
This object will show a circle and text at same size on layers of different scales. I have tried this with ViewPorts.
Regards,
Jeff
code:
PROCEDURE MyScale;
{ JAK 3/13/03 }
VAR
A, theFactor, theLayerScale : REAL;
theScale : STRING;
{** Get Units stuff}
UPI : REAL;
Fmt : INTEGER;
UM, UM2 : STRING;
UName, DA : LONGINT;
{** Regeneration state globals}
gParmN: STRING; {** my name}
gParmH: HANDLE; {** my object in drawing}
gRecH: HANDLE; {** my record}
gWallH: HANDLE; {** The wall I am currently inserted into, if any}
saveClass, noneClass :STRING;
FUNCTION getScaleFactor : REAL;
BEGIN
IF IsNewCustomObject(gParmN) OR (GetLayer(gParmH)=NIL) THEN
getScaleFactor:=1
ELSE
getScaleFactor:=GetLScale(GetLayer(gParmH)) / GetLScale(ActLayer);
END;
BEGIN {** of main program}
if GetCustomObjectInfo(gParmN, gParmH, gRecH, gWallH) then
BEGIN
SetObjectVariableBoolean(gParmH, 800, TRUE);
PushAttrs;
{** scale the marker as required for the layer and the selected scale factor}
GetUnits(UName,DA,Fmt,UPI,UM,UM2);
{** error-check for possible size changes in regens}
IF IsNewCustomObject (gParmN) OR (GetLayer(gParmH)=NIL) THEN
theLayerScale:=GetLScale(ActLayer)
ELSE
theLayerScale:=GetLScale(GetLayer(gParmH));
IF (pFactor <= 0) THEN
BEGIN
SysBeep;
SetRField(gParmH,GetName(gRecH),'Factor','.1');
theFactor:=.1;
END
ELSE
theFactor:=pFactor;
A :=theFactor*theLayerScale;
Message('theLS=', theLayerScale, ' theFactor=', theFactor, 'A=', A, ' getSF=', getScaleFactor, ' pST=', pScale_Text, ' TextSize=', (getScaleFactor*pTitle_Text));
{ ***** DrawConfig 1 ***** }
Oval(0, A*(-1/4"), A*1/2", A*1/4");
TextSize(getScaleFactor * pTitle_Text);
TextJust(1);
TextVerticalAlign(5);
TextOrigin(A*5/8", A*1/32");
IF pTitle<>'' THEN
CreateText(pTitle)
ELSE
CreateText(' ');
PopAttrs;
END;
END; {** of main program}
RUN (MyScale);
[/code]
Hi,
I'm not sure this is relevant in this case... but as I've done some 'scale independent' PIOs I noticed that on special ocasions they can regenerate while not being at the active layer, making the text size go wrong.
So I have added some code before and after the drawing procedures that make the parent layer (if found) temporarily active.
rgrds,
Alexandre
