justin1974 Posted March 31, 2005 Share Posted March 31, 2005 Simple request yet can't get to work. I have a simple Grid line marker. Graphically it consists of a circle with a bit of text eg: "x1" I'm using a pop up menu for scale; 5,10,25,50,100,200. to adjust the size of the circle and the text. The idea is that I can work on my building sections at layer scale of 10 to see the details, while using a viewport of scale 1-50. to print sections. Hence PIO will controll the correct scale apearance of the Grid Buble for the viewport independent of the scale of drawing. I have no problem in scaling the circle however I can't get the text to stay constant. When I insert the PIO on layers of different scales the text size changes in relation to the circle size. Im using settextsize(lnewobj,0,5,2mm*scale); I'm guessing that settextsize references the layer the object is on to figure out how big 2mm is. Any one know a way arround this?. Quote Link to comment
Guest Posted April 1, 2005 Share Posted April 1, 2005 I dug up a sample plug-in object script that I wrote a couple years ago that does something similar to what you want. This script is for a linear plug-in object the has the following parameters: code: LineLength Line Length 1 Factor Number 1 Title Text Integer 14 Title Text Your Title Here Scale Boolean TRUE Scale Text Integer 12[/code] The "Scale" parameter was just used to force a regen (reset) of the object for testing purposes. You won't need that. Also, if you go to the Properties dialog when creating your plug-in object, you can turn on the "Reset on Move" flag. This will force a reset when you paste the object onto a different layer. ( A paste is considered a Move.) I think there is a bug in that "Paste In Place" doesn't cause the reset, but we'll fix that in next version. This object will show a circle and text at same size on layers of different scales. I have tried this with ViewPorts. Regards, Jeff code: PROCEDURE MyScale; { JAK 3/13/03 } VAR A, theFactor, theLayerScale : REAL; theScale : STRING; {** Get Units stuff} UPI : REAL; Fmt : INTEGER; UM, UM2 : STRING; UName, DA : LONGINT; {** Regeneration state globals} gParmN: STRING; {** my name} gParmH: HANDLE; {** my object in drawing} gRecH: HANDLE; {** my record} gWallH: HANDLE; {** The wall I am currently inserted into, if any} saveClass, noneClass :STRING; {---------------------------------------------------------------------------} FUNCTION getScaleFactor : REAL; BEGIN IF IsNewCustomObject(gParmN) OR (GetLayer(gParmH)=NIL) THEN getScaleFactor:=1 ELSE getScaleFactor:=GetLScale(GetLayer(gParmH)) / GetLScale(ActLayer); END; {-------------------------------------------------------------------} BEGIN {** of main program} if GetCustomObjectInfo(gParmN, gParmH, gRecH, gWallH) then BEGIN SetObjectVariableBoolean(gParmH, 800, TRUE); PushAttrs; {** scale the marker as required for the layer and the selected scale factor} GetUnits(UName,DA,Fmt,UPI,UM,UM2); {** error-check for possible size changes in regens} IF IsNewCustomObject (gParmN) OR (GetLayer(gParmH)=NIL) THEN theLayerScale:=GetLScale(ActLayer) ELSE theLayerScale:=GetLScale(GetLayer(gParmH)); IF (pFactor <= 0) THEN BEGIN SysBeep; SetRField(gParmH,GetName(gRecH),'Factor','.1'); theFactor:=.1; END ELSE theFactor:=pFactor; A :=theFactor*theLayerScale; Message('theLS=', theLayerScale, ' theFactor=', theFactor, 'A=', A, ' getSF=', getScaleFactor, ' pST=', pScale_Text, ' TextSize=', (getScaleFactor*pTitle_Text)); { ***** DrawConfig 1 ***** } Oval(0, A*(-1/4"), A*1/2", A*1/4"); TextSize(getScaleFactor * pTitle_Text); TextJust(1); TextVerticalAlign(5); TextOrigin(A*5/8", A*1/32"); IF pTitle<>'' THEN CreateText(pTitle) ELSE CreateText(' '); PopAttrs; END; END; {** of main program} RUN (MyScale);[/code] Quote Link to comment
Alexandre Villares Posted April 3, 2005 Share Posted April 3, 2005 Hi, I'm not sure this is relevant in this case... but as I've done some 'scale independent' PIOs I noticed that on special ocasions they can regenerate while not being at the active layer, making the text size go wrong. So I have added some code before and after the drawing procedures that make the parent layer (if found) temporarily active. rgrds, Alexandre Quote Link to comment
