Trouble with Insert() Procedure
PeterT
Hi,
I am trying to write a script that adds a user entered number to the end of a specified text string found on the drawing.
The Message() line I put just before the Insert() line returns the correct values for the variables plndig and plnlbl, but the Insert procedure is not inserting plndig after plnlbl as I wish.
I am not at all familiar with using DYNARRAY of CHAR variables.
It seems I can interchange STRING and DYNARRAY of CHAR variables without errors, but I am a bit confused on the whole thing. I get the script to compile, but it does nothing to the "FLOOR PLAN' text block.
Can Anyone help with what my code is missing?
code:
PROCEDURE NumberPlan;
VAR
plnnum: REAL;
FUNCTION PlanNum(lblhndl: HANDLE): BOOLEAN;
VAR
plndig:STRING;
plnlbl: DYNARRAY[ ] of CHAR;
objtype, flrpln: INTEGER;
BEGIN
objtype:=GetType(lblhndl);
IF (objtype = 10) {if a text block}
THEN BEGIN
plnlbl:= GetText(lblhndl);
flrpln:=POS('FLOOR PLAN',plnlbl);
IF flrpln<>0 {if text block contains 'FLOOR PLAN'}
THEN BEGIN
plndig:= Num2Str(0,plnnum);
{Message(plndig, plnlbl);}
Insert(plndig,plnlbl,11); {insert plan number after 'FLOOR PLAN'}
END;
END;
END;
BEGIN
plnnum := RealDialog('Enter the Plan Number', '1 ');
ForEachObjectInLayer(PlanNum,1,0,0);
END;
RUN(NumberPlan);
[/code]
Thanks for any input.
