Hunter B Posted November 11, 2002 Share Posted November 11, 2002 I'm Using the Curtain Tool ... When I switch to a front view and reder it I get a weird set of lines. It looks like as ifthe tool reders correctly and then applies another drape over the top of it that is pulled to the left ... so you get these angled drape lines intersecting the drape that hangs correctly. I've got a jpeg of the image but cannot figure out how to post it to this board. How do I solve this problem to get it to reder properly Quote Link to comment
Vectorworks, Inc Employee klinzey Posted November 11, 2002 Vectorworks, Inc Employee Share Posted November 11, 2002 Change the 3D Resolution parameter on the object info palette to a lower number. Quote Link to comment
Hunter B Posted November 18, 2002 Author Share Posted November 18, 2002 Thanks!!! This takes out a lot of the extra lines but have you noticed that when you print the evelation of a drape, the drape doesn't hang straight... I understand that there are folds or fullness in the drap but it looks as if the "cone" of the fold in the front elevation is slanted... as if the drape is attached to something and then is pulled stage left. I was wondering if there is something I can do about this so when I render a close up it looks accurate. Quote Link to comment
