Date Within Title Symbol
GJ
I'm attempting a script that will enter a symbol with the definition of "title" and edit an object with the name of "date". I've got the date script written, but I get all kinds of errors in when I try to add it to editing a specific symbol definition.
Can anyone help me with this?
Attached is the change date and print script I wrote:
PROCEDURE DateandPrint;
VAR
dateNow : STRING;
obHd : HANDLE;
BEGIN
dateNow := DATE(1, 0);
obHd := GETOBJECT('Date');
SETTEXT(obHd, dateNow);
DOMENUTEXTBYNAME('Print', 0);
END;
RUN(DateandPrint);
GJ,
Is the object in the symbol a text object? I ran your script and got no errors changing a text object inside a symbol. VW 10.5.0 on MAC OS 10.2.8.
To see the changes to the symbol in your drawing you will have to put a RedrawAll; after the SetText(); command.
Even without the RedrawAll;, the printed output showed the updated date.
Since named objects are unique, you don't have to edit the symbol definition to modify the DATE string inside, just run the code you have above. There will only be ONE object in your file named DATE, and even if it is in a Symbol Definition, GetObject('DATE') will return a handle to it.
Can you list the errors you are getting, or the symptoms? Maybe I don't understand exactly what you are doing, so it will help clarify things.
Raymond
