Richie Hatch
Scale Objects Script
Hi
I know absolutley nothing aout scripts aprt from what they do...! I have a situation that i have to scale various items (text, rectangles, circles....) all by '.5'. When I select all the items and choose scale objects from the Tool Menu it scales everything but does so relative to the entire selection, in doing so moves items out of there originally position. I can do each item individually but was wondering if it was possible to write a script that I could first select a single item and then press the script command (or appoint a keyboard command to it) to scale the object by .5.....?
Not sure how clear that is.. Worth a try...!
Richie
They are many ways to do this, but this script keep the normal operator logic:
-ask for a scaling factor
-memorizes all the selected objects
-deselect everything
-select each object to apply the scale factor
-reselect everything to keep working
It works (so far!), and is an easy insight into VW functionality.
code:
Procedure Individual_Scale;
{debug}
VAR
x,y: REAL;
h: HANDLE;
i,j: INTEGER;
MyH: DYNARRAY [] OF HANDLE ;
BEGIN
x:=RealDialog ( 'enter a scaling factor','0.5');
y:=x;
h:=ActLayer;
j:=NumSObj(h); {how many objects}
ALLOCATE MyH[1..j]; {allocatating the memory}
h:=FSActLayer;
FOR i:=1 TO j DO BEGIN {this keep on memory the objects handle}
MyH
:=h;
h:=NextObj(h);
END;
DselectAll; {we deselect everything}
FOR i:=1 TO j DO BEGIN {this select each object and apply the scale procedure}
SetSelect(MyH
Scale(x,y);
SetDSelect(MyH
END;
FOR i:=1 TO j DO BEGIN {this select all the scaled objects}
SetSelect(MyH
END;
END;
RUN (Individual_Scale);
[/code]
Hi Kiwi,
Nice script, thanks. I think you need one change in the loop where you save the handles. You have:
MyH:=h;
h:=NextObj(h);
END;
I think "h:=NextObj(h);" should be "h:=NextSObj(h);", so it just saves the handles of selected objects.
All the best,
Raymond
Going too fast as usual [Roll Eyes] I agree on the correction... Thanks Raymond [smile]
Hi All
I tried the following script, but I make something wrong. Does anybody see what I do wrong?
Thanks, Marc
VAR
x,y: REAL;
h: HANDLE;
i,j: INTEGER;
MyH: DYNARRAY [] OF HANDLE;
BEGIN
x:=RealDialog ( 'Skalierungsfaktor','0.5');
y:=x;
h:=ActLayer;
j:=NumSObj(h);
ALLOCATE MyH[1..j];
h:=FSActLayer;
MyH:=h;
h:=NextSObj(h);
END;
END;
DselectAll;
SetSelect(MyH);
Scale(x,y);
SetDSelect(MyH);
END;
SetSelect(MyH);
END;
END;
Edited by MaWi
Hello Marc,
   There are two problems. First, you have an extra "END" in the middle of the program that needs to be removed. Second, when you make individual references to the handles in your array you need to add a subscript to indicate which one you want.  Eg. where you have   MyH := h;   you should have   MyH[index] := h;.   I marked these below. Make these changes and it will work.
HTH,
Raymond
PS - Your code may be indented on your computer, but the example above is not. If it isn't, doing so will help you see mismatched BEGIN/END's more easily.
VAR
	x,y: REAL;
	h: HANDLE;
	i,j: INTEGER;
BEGIN
	y:=x;
	h:=ActLayer;
	j:=NumSObj(h);
	ALLOCATE MyH[1..j];
	h:=FSActLayer;
		MyH[i]:=h;			{ need array reference [i] }
		h:=NextSObj(h);
	END;
{	END;			<= this END shoud not be here. Remove it. }
	DselectAll;
		SetSelect(MyH[i]);		{ need array reference [i] }
		Scale(x,y);
		SetDSelect(MyH[i]);		{ need array reference [i] }
	END;
	END;
END;
Edited by MullinRJ
Hi Raymon
Thanks for your heldp!
Mister Marionette DomC helped me. We change the script to Phyten :-)
Best regards, Marc
x=y=0.5
h=vs.FSActLayer()
counter = 0;
while h!=None: #the same like vs.Handle(0)
    p1,p2=vs.HCenter(h)
    vs.HScale2D(h, p1, p2, x, y, True)
    h=vs.NextSObj(h)
    counter +=1
    if counter > 100000:
        break
vs.ReDrawAll()
You're welcome,
That works, too. And, it's better written. I hope you'll keep trying your hand at scripting. It's a great tool and makes VW extremely powerful. If you get stuck with anything, post your questions here. This forum is incredibly helpful. Hope to see around.
Raymond
