James Pitt Posted February 21, 2005 Share Posted February 21, 2005 More of an enquiry really as to whether anyone else has written a script which causes the standard Visual C++ runtime error. "This application has requested the runtime to terminate it in an unusual way". This error only occurs in the one script I am producing and has not occured in previous revisions of the same script. Can anyone help? James Pitt Tested on Vectorworks 10.1 -> 10.5.1 (Windows) Quote Link to comment
James Pitt Posted February 21, 2005 Author Share Posted February 21, 2005 Additionally, it may be worth a mention that the script compiles ok, it even completes ok, and I can view the drawing it creates. However, once I have zoomed in and out a little, or everytime I close the drawing it produces the error. The script is over 49kb in size. Is there a limit? Is there an error log? Quote Link to comment
James Pitt Posted February 21, 2005 Author Share Posted February 21, 2005 I believe I have identified the cause of the problem, however I still don't understand why. {In the case below handles have been assigned to the first stud and the last stud and also during a loop to all the inbetween studs using a dynarray. A flatstrap is placed over these in certain cases and we must show the overlap, hence intersect and clip} referenceflatstrap := LNewObj; FOR i := 1 TO totalstuds DO BEGIN PenPat(-3); h := IntersectSurface(referencestud,referenceflatstrap); ClipSurface(referencestud,referenceflatstrap); END; Quote Link to comment
James Pitt Posted February 21, 2005 Author Share Posted February 21, 2005 Problem solved : the process has changed and i no longer need to clip the items It would be interesting to know why these functions and procedures seem to cause runtime errors though. Quote Link to comment
kiwi Posted February 21, 2005 Share Posted February 21, 2005 I'm having a similar problem, with a script forcing VW to crash after running it a few times and zooming or modifying the drawing in any way. Even after a single run, I know that soon or later the app will quit. I never found a cause, but the 2000 lines of script compiles and debug flawlessly... the only message I get is the "reassign a dynarray could cause the loss of data". At the moment I'm working on a new version with a new approach trying to overcome the problem. But I will look a the overlapping variables to see if is the cause! Quote Link to comment
James Pitt Posted February 22, 2005 Author Share Posted February 22, 2005 I now believe this is not a vectorscript issue. I am encountering the same run-time error when I open any file in Vectorworks, however, if I open the file straight from the desktop it will load up fine. Posting to General Discussion. Quote Link to comment
James Pitt Posted February 23, 2005 Author Share Posted February 23, 2005 Perhaps you could try resetting the preferences by pressing reset in vectorworks preferences menu. This solved my problems but as I have stated I don't believe the problem is to do with scripting anymore. Quote Link to comment
