Ignaceb Posted February 15, 2005 Share Posted February 15, 2005 Using my PowerBook, I like my drawing with margins right + compact palettes organised in the right margin. Using my PowerBook with a second screen, I like my drawing without margins + extended palettes organised in the second screen. Is there a script command to make the palettes appear at a fixed XY-position of the screen? Is there a script command to go to preferences / VWpreferences / sessiong / margins? Is it possible to link these scripts to the workspace? Quote Link to comment
mike m oz Posted February 16, 2005 Share Posted February 16, 2005 Try using two different workspaces: - set up one for your powebook as you want it - edit a copy of this workspace and change the pallettes to as you want them and where you want them. If I have understood your query correctly this will give you what you want. All you will have to do is change your workspace depending on which mode you are working in. Quote Link to comment
