tdragoone Posted December 16, 2004 Share Posted December 16, 2004 Ok, I must warn you I am extremely new to this, but very willing to learn. A while back, when I first started using VW, I was having difficulty with plotting drawings. The problem was: when I wanted to change the doc prefs to b&w only....... some of the lines would disappear. The work around resulted in the following script: {====== BEGIN SCRIPT =======} Procedure Swap; Procedure SwapBGFG(h:HANDLE); BEGIN SetLS(h,2); END; BEGIN ForEachObject(SwapBGFG,ALL); END; RUN(Swap); {====== END SCRIPT =======} I used the script to create a command that I would invoke prior to changing the doc prefs to B&W only. This has worked fine for months. The problem now is: I would like to take it to the next level. I have been trying to figure out how to combine this script with the one that changes the doc prefs to B&W only. I would then like to make it a command that i could invoke before plotting. Any help / suggestions would be greatly appreciated. Thanks, Tom Quote Link to comment
PeterT Posted December 18, 2004 Share Posted December 18, 2004 For B&W only, just put SetPref(10,TRUE); before the last END statement. Quote Link to comment
