Damo Posted October 15, 2004 Share Posted October 15, 2004 Im structural engineer who is creating a drawing showing piles (a symbol). I would like to link the insertion coordinates of each pile (Labelled P1, P2 etc. into a worksheet. This worksheet would show Pile ref: (P1) and then the x and y insertion coordinatesof the symbols. can anyone help me please (not that great with scripts !) Quote Link to comment
Petri Posted October 15, 2004 Share Posted October 15, 2004 No scripting needed - you can just use the worksheet (report) to get the locations. Depending on the design of symbols, different functions are needed, but I would suggest a design where =XCENTER and =YCENTER provice correct results. Labelling is best handled with a data record, so you can show the numbers on the drawing with linked text. Quote Link to comment
Damo Posted October 21, 2004 Author Share Posted October 21, 2004 Petri Thanks for reply, my symbol insertion is not symbol xcenter/ycenter so it is giving me incorrect coordinates. What i need is insertion x and y, does this exist ? Quote Link to comment
Petri Posted October 23, 2004 Share Posted October 23, 2004 Sorry, Damo - not with worksheets and symbols, but if instead of symbols you would use (simple) parametric objects, they would work (via a data record.) The script of the PIO might be something like this: code: { -------- START SCRIPT -------- } PROCEDURE xyMarker; { ? Petri Sakkinen 2002 - 2004 } CONST rName = 'refdata'; { the name of the data record you wish to use } xField = 'xCoord'; { and the names of the fields } yField = 'yCoord'; lineLength = 500mm; { modify constants so the size suits you } textX = 700mm; { ditto with tag locations } textY = 700mm; VAR x, y, xo, yo : REAL; me, rHd, wHd : HANDLE; myName, xCoord, yCoord : STRING; ok : BOOLEAN; BEGIN ok := GETCUSTOMOBJECTINFO(myName, me, rHd, wHd); SETOBJECTVARIABLEBOOLEAN(me, 800, TRUE); GETSYMLOC(me, x, y); x := x - PXREF; { we have parameters for coordinate reference } y := y - PYREF; { point in case of a specific local coord origin } xCoord := NUM2STRF(x); yCoord := NUM2STRF(y); SETRECORD(me, rName); SETRFIELD(me, rName, xField, xCoord); SETRFIELD(me, rName, yField, yCoord); xCoord := CONCAT('x ', xCoord); yCoord := CONCAT('y ', yCoord); MOVETO(-lineLength, 0); { crosshair lines } LINETO(lineLength, 0); MOVETO(0, lineLength); LINETO(0, -lineLength); TEXTORIGIN(textX, 0); CREATETEXT(yCoord); SETTEXTVERTICALALIGN(LNEWOBJ, 3); SETTEXTJUST(LNEWOBJ, 1); TEXTORIGIN(0, textY); TEXTROTATE(90); CREATETEXT(xCoord); SETTEXTVERTICALALIGN(LNEWOBJ, 3); SETTEXTJUST(LNEWOBJ, 1); END; RUN(xyMarker); { -------- END SCRIPT -------- } [/code] The PIO properties must be 'Reset on move'. Note that you only need to modify the constants to customise the marker a bit, like size & the record/fields you wish to use. Note also that this only does x & y, but you can easily add z with function GETSYMLOC3D(me, x, y, z) and by adding a third text creation/data writing module. [ 10-22-2004, 09:09 PM: Message edited by: Petri ] Quote Link to comment
