tom kyler_dup1 Posted October 8, 2004 Share Posted October 8, 2004 I have a linear plug-in object that draws an object with some text near it. When I select this object and change the font from the main menu, the font doesn't update in real time. I have to deselect the item, change the font, reselect the item and then resize it to get the script to recalculate with the new font. The function I'm unable to find in the reference is one that reads the current active font and allows me to apply it to the selected object...or at least I could use an understanding of what happens to a selected object when the font menu is changed from one font to another. Basically, I want to select my linear plug-in object, go to the font menu, change the font, and have my item updated at that time. Anybody know which function I'm missing? [ 10-08-2004, 04:50 PM: Message edited by: tom kyler ] Quote Link to comment
MullinRJ Posted October 10, 2004 Share Posted October 10, 2004 Tom, Do you set the font face from within your script? I have seen PIO's accept color, font face and size changes by selecting the PIO and using menu options to apply them, but you may have a problem if your script sets them explicitly. Also, what properties are set for the PIO? The one I examined had the RESET button highlighted with no checkboxes selected. Raymond Quote Link to comment
tom kyler_dup1 Posted October 11, 2004 Author Share Posted October 11, 2004 Raymond, I do not explicitly set the font. I do set the alignment, and use a pull-down menu in the OIP to set the size, so I do set some text properties explicitly, but not the font. If I were to change the font on the pull-down menu Quote Link to comment
patman Posted October 20, 2004 Share Posted October 20, 2004 Include this line of code in your script and it will enable the font menu. SetObjectVariableBoolean(gObjHd, 800, TRUE); where gObjHd is the handle to the PIO. Patrick Quote Link to comment
