carch
convert vectorscript 9.5 to vectorscript 11
Can you take a vectorscript 9.5 or 10 and convert it to vectorscript 11? If so, how?
thanks
chris
quote:
thanks
chris
Probably yes.
1- Document scripts (you double click them in a command palette inside your vectorworks file). Just open your file on VW 11 and see if using them generates any errors.
2- Plug-in tools, objects (you pick them from a palette) or command menus. Copy the relevant files to the VW 11 plug-ins folder, add them to a workspace and see if using them generates any errors.
Errors, if any, are usually due to functions/procedures that became obsolete but those may be replaced with a bit of coding work if the script is unlocked (if you can actually view and edit the code).
[ 11-15-2004, 04:07 PM: Message edited by: Alexandre B A Villares ]
