ezaytsev Posted June 9, 2004 Share Posted June 9, 2004 Help me please! I would like to use Modern Dialog (CreateLayout) with specific control. Usually Dialog Window closes after press 'OK' or 'Cancel' button. Is it possible to close Dialog Window after press non standard push buttons? Please advice how to do it? Evgeny Quote Link to comment
PeterT Posted June 9, 2004 Share Posted June 9, 2004 Check the VectorScript Archives for the answer to this one. There was a discussion on this back on May 30 or so. http://lists.nemetschek.net/archives/vectorscript-l.html Here is a snippit from the thread: ---------------------------- Subject: Re: How to close a Modern dialog Gerard, The way I do it is like in the code below. The statement "item := 1" is the only additional code required to close the dialog. Your message sounds like you're doing more than necessary... Matt ---------------------------------------------------------------------- CASE item OF {- dialog init -} SetupDialogC: BEGIN {Your code here} END; {- dialog cleanup -} SetdownDialogC: BEGIN {Your code here} END; { - OK button case - } 1: BEGIN {Your code here} END; { - Cancel button case - } 2: BEGIN {Your code here} END; { - Popup Menu case - } PopupMenuID: BEGIN IF {Your code here} THEN item := 1; <--- THIS CLOSES THE DIALOG END; END; {CASE} ---------------------------------------------------------------------- Quote Link to comment
