Point Object and Records
Hello, first of all excuse me for my english...
I wrote a "point object" with vectorscript. I cannot understand how to define fields in a record ad the same time when the object is created.
In a document I create a record (DIMENSIONS) with the following fields:
DIAMETER
LENGHT
I would like put automatically the Parametric Data in the fields so in the "point object" script i use this functions:
SetRecord(handle,recname);
SetRField(handle,recname,field,string);
I cannot understand which kind of handle i have to use to fill-in the field at same time when the object is placed. I tried in many different ways but nothing to do! It doesn't works... [Frown] (
Someone can help me? Thanks a lot
This is the complete script:
Procedure curva;
VAR
sin45,cos45,sin30,cos30,x,y,x1,y1,x2,y2,x3,y3:real;
recname,valorediam:STRING;
BEGIN
SetRecord(FActLayer,recname);
SetRField(FActLayer,recname,'tipo','curva');
SetRField(FActLayer,recname,'diametro',valorediam);
recname:='dimensioni';
valorediam:=num2str(3,PD);
sin45:=sin(0.785398163);
cos45:=cos(0.785398163);
sin30:=sin(1.047197551);
cos30:=cos(1.047197551);
x:=PD-(cos45*0.5*PD);
y:=-PD+(sin45*0.5*PD);
x1:=PD-(cos45*1.5*PD);
y1:=-PD+(sin45*1.5*PD);
x2:=PD-(cos30*0.5*PD);
y2:=-PD+(sin30*0.5*PD);
x3:=PD-(cos30*1.5*PD);
y3:=-PD+(sin30*1.5*PD);
if (Pangolo='90') then
begin
arc(-PD/2,PD/2,5/2*PD,-5/2*PD,#90?,#90?);
arc(PD/2,-PD/2,3/2*PD,-3/2*PD,#90?,#90?);
moveto(-PD/2,-PD);
lineto(PD/2,-PD);
moveto(PD,PD/2);
lineto(PD,-PD/2);
locus(0,0);
end
else
if (pangolo='45') then
begin
arc(-PD/2,PD/2,5/2*PD,-5/2*PD,#90?,#45?);
arc(PD/2,-PD/2,3/2*PD,-3/2*PD,#90?,#45?);
moveto(x,y);
lineto(x1,y1);
moveto(PD,PD/2);
lineto(PD,-PD/2);
locus(0,0);
end
else
if (pangolo='30') then
begin
arc(-PD/2,PD/2,5/2*PD,-5/2*PD,#90?,#30?);
arc(PD/2,-PD/2,3/2*PD,-3/2*PD,#90?,#30?);
moveto(x2,y2);
lineto(x3,y3);
moveto(PD,PD/2);
lineto(PD,-PD/2);
locus(0,0);
end;
end;
run(curva);
  • 3 weeks later...
I use GetCustomObjectInfo(objName,objHand,objRecHand,wallHand);
SetRecord(objHand,recname);
SetRField(objHand,recname,'diametro',valorediam);
GetCustomObjectInfo will get the handle to the PIO that it is called in,along with the other handles. In this case objRecHand is the handle to the record that contains the parameter values of the PIO and not the record that you are attaching.
Also, you might want to move this stuff to the end of the script so that the variables recname and valorediam have been assigned values before you call them.
You can also use 'dimensioni' directly in SetRField instead of a variable if you want. Either way you use it ,make very sure that it is typed exactly the same as the name of the record.....obvious I know, but it's happened to me with a space that shouldn't be there.
Hope this works for you
charles
