Measuring Nurbs Length
I'm afraid I'm not fit to help you with the actual script part,
but if you start with a poly; the "perimeter" is already given in the OIP. A script that created a record of that before converting to NURBs might do it. (?)
Not much help if you edit the NURBs afterwards though. :-(
cheers
N.
You can try this..
Procedure GetTotalLength;
VAR
fraction, display : LONGINT;
format: INTEGER;
origLength: REAL;
BEGIN
if FSActlayer = NIL then begin
Message('Please select any line or wall.');
end
else begin
origLength := Length(Sel=true);
Message('Total Length = ', origLength /10^3:0:3,' Metres');
end
END;
Run(GetTotalLength);
I hope it can help.
G-Pang
G5 2.0 DP.4 GB Ram Apple 23" HD
