  • 5
Move Drawing AND User Origin to Internal
jacobjz
8 answers to this question
@jacobjzCan I ask you for the workflow you need this for? We're working on GIS and origin improvements, and want to ensure all workflows are covered. What do you want to see as a result - do you want to see the User Origin aligned with the internal Origin (so it reads 0,0) or do you want the user coordinates of the project to follow if you move the project (so if you have a point in the project that reads x=291000, y=93000 and that you want aligned with the IO - should those coordinates follow along?)
Also, are you using georeferencing, or only the User origin coordinates?
@Katarina Ollikainen Sorry I'm not totally sure I'm following the difference.
I work in Entertainment, and I never georeference. Generally I set the user origin to be on centerline of the theater and the "plaster line" of the proscenium and all coordinates are relative to that.
Once I set my User Origin I'd like to be able to re-align the user origin along with the whole drawing to the internal origin so that they are the same thing.
@Tom W. is correct - you can do this today by moving the project as he describes. Just remember to make all classes and layers visible before creating the circle - otherwise you might miss something.
So for the request above, use the following workflow:
  • Set the User Origin where you want it
  • Make all geometry visible
  • Draw a circle, starting on the 0,0, that encompasses all geometry - this is important!
  • Use the command Tools>Origin>Center Drawing on Internal Origin - this will move all the geometry and the user origin coordinates so the 0,0 will align with the Internal Origin.
The 'one-click' function exists if you're using the Survey Point, but for that, the file and layers need to be georeferenced. The difference here is that the move is based on the survey point alone, so you don't need to find all the geometry and draw the circle.
This will not fix any later import issues, though, if what you import doesn't have the IO or UO in the same place (depending on your import alternative).
