Issue with rack ruler in 2D rack elevation
Hello, ive created some racks in 3D andcl placed some equipments. Then i selected the racks and created a rack elevation. All seems ok. However i try to add a rack ruler the racks its way too big and not scaled. There is setting to scale. Is there spmething im doing wrong?
Check if your content is really vector-based
Zoom in very close on your drawing: if the lines stay sharp (not pixelated), it’s vector data.
If you imported a 3D model (e.g., SketchUp), some views may display as raster images. To get vectors, you need to use a Hidden Line or Wireframe view
Create a Sheet Layer
Go to View → Create Sheet Layer (or in the Navigation palette: New Sheet Layer).
Place a Viewport from your design layer onto this sheet layer.
Important: In the viewport’s Render settings, choose Wireframe or Hidden Line.
Other render modes (e.g., OpenGL/Renderworks) will rasterize the drawing and won’t export as vectors.
Export to PDF with vector options
Go to File → Export → Export PDF…
In the dialog:
Check “Export as Vectors” (very important!)
If you have raster images in the drawing (textures, renderings), enable “Rasterize Images” so they are embedded alongside vectors.
Set Resolution high if you’re including any raster elements
Rendered views (OpenGL, Renderworks, Shaded) are always rasterized → no vector export.
2D plans and Hidden Line views keep vector properties intact.
For 3D models, create section viewports or hidden-line viewports to generate clean vector output
