Developer Wiki and Function Reference Links Read more... ×
hong
compose
Is there a script command for this?
Compose command is under pull down menu and I am trying to insert the same command inside of a script. But I don't seem
to find it in the list of script command.
Thanks in advance.
I tried this and VW crashed.
I did not see this 'compose' on VW script reference appendix H where it lists menu list.
As Dave mentioned, the DoMenuTextByName call should work. I just tried it and didn't crash. If yours is crashing it is probably due to the objects that are selected when you run the script. Log a bug and provide the drawing file or describe the types of objects you are using.
The VectorScript Function Reference Appendix H lists the old name of this menu command: "Compose Curve". It was renamed to "Compose". I will update the documentation.
Thanks,
Jeff
