nbakovic Posted July 23, 2025 Share Posted July 23, 2025 For color coding purposes, I am trying to get a small rectangle to change automatically when sheet data in the title block is modified. I created a network that gets that record field information from the title block on the sheet layer that the network is placed on. It works as expected except that I have to manually refresh the object node to have it change the color when the sheet data changes. I've tried doing dummy geometry and control point placement and anything else I could find/think off to solve this issue and I have had no luck. Does anyone have any ideas? CAS Template 2025 DRAFT.vwx Quote Link to comment
Pat Stanford Posted July 24, 2025 Share Posted July 24, 2025 VW really does not have a way for an object to realize when something else in the drawing has changed. Especially not something like data in the title block. The only thing that I am thinking MIGHT possibly work would be for your network to change a Class Fill setting and have the rectangle use that Class Fill. But you are still not going to automatically get the network to run when you make the change. 1 Quote Link to comment
Antonio Landsberger Posted July 24, 2025 Share Posted July 24, 2025 Hi @nbakovic What you want is either an event triggered script run, which Marionette and scripts have no access to or knowledge of, or a script that runs in certain intervals to check for changes. The latter is also not possible, because that would essentially be a script running in the background, but Vectorworks is always blocked during script runtime, thus there could also be no change to check while the script is running. You could create a menu command (from a Marionette wrapper), that shows you the relevant information you want to see - no matter where in the document you are. It could even be information from different objects and records (all in this one message). Quote Link to comment
nbakovic Posted July 24, 2025 Author Share Posted July 24, 2025 Thanks @Antonio Landsberger, I was afraid that it was something like that. I appreciate the idea of the menu command, and there might be something there for me to explore, but this is more intended as a color coding system for published PDFs. I work in exhibit design and the vast majority of people in this field aren't architects or designers and they struggle with reading them so I working on making it as easy as possible, which is where this originated form. Quote Link to comment
Pat Stanford Posted July 24, 2025 Share Posted July 24, 2025 Take a look at Data Visualization. That might be able to do what you want. 2 Quote Link to comment
