Problem with function GetPtL
ezaytsev
Could anyone help me? I use function GetPtL in script and i have a problem. If start and end points are equal then i have artefact - thin line from end point to the point (0,0). Now I use VW 10.01 for PC. In version 8.5 there is no such problem. I think this is problem of VW10.
Procedure WireTool;
VAR
x,y,x1,y1 : REAL;
Procedure Lines;
BEGIN
MoveTo(x,y);
LineTo(x1,y1);
SetDSelect(LNewObj);
ReDraw;
END;
BEGIN
DSelectAll;
GetLine(x,y,x1,y1);
Lines;
i:=0;
Repeat
x:=x1;
y:=y1;
GetPtL(x,y,x1,y1);
Lines;
i:=i+1;
Until (x=x1) and (y=y1);
END;
RUN(WireTool);
Help me please!
I'm not sure why the artifact, but is just a visual one: try to zoom out or in too see it disappear. A RedrawAll at the end of the script should help too. but the last line seems to have another artifact: a kind of "hole".
If you click a bit so fast to end the last line, VS get a double click and he seems that GetPtL get a problem with that!
I send you another version of the same script from another point of view, and where the lines are force to be redraw by reseting the Bbox. We still get an artifact (??) when using GetPtL, but once the end click, the drawing looks OK.
Could be easier to draw a poly and then transform to lines using a couple of shortcuts!
code:
Procedure WireTool;
VAR
pt1,pt2 : POINT;
o: BOOLEAN;
BEGIN
DSelectAll;
GetPt(pt1.x,pt1.y);
MoveTo(pt1.x,pt1.y);
WHILE NOT o DO BEGIN
GetPtL(pt1.x,pt1.y,pt2.x,pt2.y);
o:=(pt1=pt2);
IF NOT o THEN BEGIN
LineTo(pt2.x,pt2.y);
ResetObject(LNewObj);
Redraw;
END;
pt1:=pt2;
END;
RedrawAll;
END;
Run(WireTool);
[/code]
Thank You!
I have already used RedrawAll function, but artefact still appears for short time. Moreover sometimes short double click doesn't work properly. It's really strange, but in 8.5 version script works fine, and there are no artefacts at all. Can you please comment the script in version 10.5? Is this error in GetPtL function fixed?
