Guest Posted January 5, 2004 Share Posted January 5, 2004 I cannot get setVSResourceFile to find the resource file that I am looking for. Is the default path for this call the VW folder or is it the desktop? What kind of file is the resource file supposed to be? I'm looking to put an image that is created in VW into a custom dialog box? Can someone please point me in the right direction? Thanks, Dave. Quote Link to comment
Guest Posted January 14, 2004 Share Posted January 14, 2004 The default path for SetVSResourceFile is in the Plug-ins folder. Quote Link to comment
Guest Posted February 2, 2004 Share Posted February 2, 2004 I found out where the file is supposed to go and according to SetVSResource file VW can see the file. However I'm still not getting the image out of the file. What type of resource does the image have to be. How do I call a particular image within the resource file for it to show up in my dialog as an image pane? Quote Link to comment
ccroft Posted February 3, 2004 Share Posted February 3, 2004 Try searching the archives here: http://lists.nemetschek.net/archives/vectorscript-l.html I've seen a few posts about this,but as yet haven't used it myself. Does your file have ".rsr" suffix? Quote Link to comment
Guest Posted February 3, 2004 Share Posted February 3, 2004 Yes my file has the correct extension. SetVSresourcefile returns true so it is able to open the file. I'm just not able to get the image to show up!? I don't know if the image inside the rsrc file is supposed to be a PICT or a CRS or what. I've created the rsrc files using ResEdit. I just can't figure out the format I'm supposed to create the image in. Or am I missing some call? I used Dialog Builder 4 to try and put an image in and it is using the same calls as I am and still does not show an image. Quote Link to comment
Guest Posted February 4, 2004 Share Posted February 4, 2004 Alright I figured it out. The resource file must be in your plug-ins folder. The resource file must contain PICT files. The data field of CreateControl item must be the ID number of the image within the resource file. What a rash! It would be nice if this was documented in the vectorscript help! Thanks for everyones input, Dave Quote Link to comment
