Layers Class fast switching script
kiwi
A little while ago, on a topic I don't remember, somebody gave me the idea for this script... But I never really take the time for it. Fed up by the mousing each time I want to send series of objects to a class or layer, I have a go at it. Since the idea come from the forum, and the subject has been coming back time to time, I'm quite happy to share the code.
I would much appreciate to see interesting developments or ideas related to this script... is actually one of the interest of having a forum: share opinions and point of views, not only solve problems!
He should work with all selected objects, and the function ForEachObject() could look inside groups or symbols with a different search criteria (I have a version that send specific object types thanks to another entry to the dialog).
I've add a couple of options to follow the object (s) to the new layer/class, and to duplicate the selection. I set it up as a plug in with a shortcut and save me a lot of boring work across the screen.
Must say thanks to the DialogBuilder developers...
code:
LayerClassT
By: <Kiwi Dec 2003>
Built with Dialog Builder 4 © 2001 Nemetschek North America.
PROCEDURE LayerClassT;
VAR
dlogID,dlogResult,nl,nc,i : INTEGER;
dialogIsOK,rsrcOK,dupl,go,dumm,OK : BOOLEAN;
h,ho: HANDLE;
Layerr,classr,currentL,currentC: STRING;
Layers,Classes: DYNARRAY OF STRING;
{ dialog related subroutines }
{ Dialog definition function subroutine }
FUNCTION Define_LayerClassT : INTEGER;
VAR
dialogID : INTEGER;
BEGIN
dialogID := CreateLayout('Layer/Class Transfer',True,'OK','Cancel');
CreatePulldownMenu(dialogID,10,25);
CreatePulldownMenu(dialogID,20,25);
CreateCheckBox(dialogID,30,'Follow objects');
CreateCheckBox(dialogID,40,'duplicate objects');
SetFirstLayoutItem(dialogID,10);
SetBelowItem(dialogID,10,20,0,0);
SetBelowItem(dialogID,20,30,0,0);
SetBelowItem(dialogID,30,40,0,0);
SetHelpString(1,'Accepts dialog data.');
SetHelpString(2,'Cancels operation without changes.');
SetHelpString(10,'Slect a layer to transfer your selected object');
SetHelpString(20,'Select the class you want your object transfer to.');
SetHelpString(30,'Go to the selected option with the actual visibility settings');
SetHelpString(40,'Select to duplicate your selected object');
Define_LayerClassT := dialogID;
END;
{ get Layer names to dinarray Layers }
Procedure GetLayers;
BEGIN
nl:=NumLayers;
AlLOCATE Layers[1..nl];
h:=FLayer;
For i:=1 TO nl DO BEGIN
Layers
:=GetLNAME(h);
h:=NextLAyer(h);
END;
END;
{ get Class names to dinarray Classes }
Procedure GetClasses;
BEGIN
nc:=ClassNum;
AlLOCATE Classes[1..nc];
For i:=1 TO nc DO BEGIN
Classes
:=ClassList(i);
END;
END;
{ Change each obj settings }
Procedure ChangeObject(ho:HANDLE);
BEGIN
h:=GetLayerByName(layerr);
SetClass(ho,classr);
dumm:=SetParent(ho,h);
END;
{ Dialog driver function subroutine }
PROCEDURE Drive_LayerClassT(VAR item:LONGINT; data:LONGINT);
BEGIN
CASE item OF
SetupDialogC:BEGIN
GetLayers;
h:=ActLayer;
CurrentL:=GetLNAme(h);
FOR i:=1 to nl DO BEGIN
InsertChoice(10,i,Layers
IF Layers
=CurrentL THEN SELChoice(10,i,true);
END;
GetClasses;
CurrentC:=ActiveClass;
InsertChoice(20,i,Classes
IF ClassList(i)=CurrentC THEN BEGIN
SELChoice(20,i,true);
END;
END;
OK:=TRUE;
END;
1:BEGIN
GetSelChoice(20,0,i,Classr);
GetSelChoice(10,0,i,Layerr);
dupl:=ItemSel(40);
go:=ItemSel(30);
END;
END;
END;
{ main body of script }
BEGIN
dlogID := Define_LayerClassT;
dialogIsOK := VerifyLayout(dlogID);
IF dialogIsOK THEN BEGIN
dlogResult := RunLayoutDialog(dlogID,Drive_LayerClassT);
END;
IF dupl THEN duplicate(0,0);
IF OK THEN ForEachObject(ChangeObject,SEL=true);
IF go THEN BEGIN
NameClass(Classr);
Layer(layerr);
END
ELSE BEGIN
Layer(CurrentL);
NameClass(CurrentC);
END;
END;
Run(LayerClassT);
[/code]
Giday Kiwi
Have tried your script .Did try to set up as plugin and as a script .I dont seem to be able to get it to read existing Layers & Classes .The
Dialog returns empty .Is there any thing I am meant to be doing with this.
Thanks for the contribution I agree with your sentiments about concepts & Ideas.
Cheers
Brendan
Got it!
The assign integer for the pull down menus start at 0 and not at 1... for some reason on a mac still work, but not on a XP. once modify he looks like:
Hope is find now....
code:
LayerClassT
By: <Kiwi Dec 2003>
VAR
h,ho: HANDLE;
VAR
dialogID : INTEGER;
BEGIN
END;
BEGIN
nl:=NumLayers;
h:=FLayer;
Layers
:=GetLNAME(h);
h:=NextLAyer(h);
END;
END;
BEGIN
nc:=ClassNum;
Classes
:=ClassList(i);
END;
END;
BEGIN
END;
BEGIN
CASE item OF
SetupDialogC:BEGIN
GetLayers;
h:=ActLayer;
InsertChoice(10,i-1,Layers
IF Layers
END;
GetClasses;
InsertChoice(20,i-1,Classes
END;
END;
OK:=TRUE;
END;
1:BEGIN
dupl:=ItemSel(40);
go:=ItemSel(30);
END;
END;
END;
BEGIN
END;
IF go THEN BEGIN
NameClass(Classr);
Layer(layerr);
END
ELSE BEGIN
Layer(CurrentL);
END;
END;
Run(LayerClassT);
[/code]
Gidday Kiwi
Got it .Dont know how u worked that out so quick.
Runnig as a script it works fine .
Just question on dialog builder.Have tried it with VWA9.5 but not in 10.Is it availiable for 10.5.
Havent seen it at NNA anywhere?.
I'll see how many times can use this in the next week.
Cheers cool tool.
Brendan
I use dialog builder 4.0b4: the plugins work find on 10.5, just drop them on the plugins folder, and set the workspace.
The debugger tells you if anything is not right, and on this case the procedures reading layers and classes work find (you can see the strings being assign), then could only be something related to the pull down menus and the way I assign the sting values.
This debugger is a wonderful think. Let's hope we will have soon a real script editor with colors, scrolling and enable us to work with too or more scripts open (like BBedit but with compile and debug).
  • 1 year later...
