GetFontID
B.Balemi
It seems that the integer returned by GetFont has something to do with that particular font's position in the list of active fonts.
I don't know what you are doing, but you could try something like: TextFont(GetFontID('Arial'));
Or you could store the result in a variable: font:= GetFontID('Arial"); and go from there using font instead of a literal.
Either way it won't matter what ID is actually returned by GetFont, as long as arial is present in the system.
If this doesn't help,you should post back with more info on what exactly you're trying to do with your script.An example of how you are using GetFont would be useful.
[ 12-01-2003, 10:24 PM: Message edited by: ccroft ]
