Developer Wiki and Function Reference Links Read more... ×
C_bonaker_1976
Exit Dialog with a Carriage Return
If you select a field in a dialog so that you can type over the current information, how do you make it so that when you hit the enter key, it automatically acts as if the ok button has been selected. I'm trying my hand at writing a tool that will allow me to update a record field attached to an object just by selecting the object and running the script. That part works. I've fed the field with the old information as a reference, then selected the field so that all you have to do is type the new value. But you have to click ok, which is much slower than just hitting return. It would be great if you typed the new number, then could hit enter to send the info. Here is the code I've started from for the dialog:
PROCEDURE Dialogstart;
VAR
item: Integer;
cancel, done : Boolean;
BEGIN
BeginDialog(1,1,100,100,300,300);
AddButton('OK',1,1,110,175,180,190);
AddButton('Cancel',2,1,20,175,90,190);
AddField('test',3,1,15,20,180,40);
AddField('test',4,2,15,60,180,80);
EndDialog;
GetDialog(1);
SetTitle('Test');
cancel := False;
done := False;
SelField (4);
REPEAT DialogEvent(item);
IF item = 2 THEN cancel := True;
IF item = 1 THEN done := True;
UNTIL cancel | done;
END;
RUN(Dialogstart);
Any Ideas? Thanks for any help.
Here's something I put together using the modern dialog commands for creating a layer and sheet in one shot. You should be able to modify it to fit your needs, the structure is there. The "return" key (carriage return) will act the same as hitting the OK button as you want.
HTH
Dave
OK, here it is, sorry fella's...
Procedure Createlayersheet;
CONST
kOK = 1;
kCancel = 2;
VAR
LayerName ,TempLayerName :STRING;
Layerhd :HANDLE;
dialogOK,Done: Boolean;
dlogID, dialogResult : LONGINT;
newname:DYNARRAY[] of CHAR;
startname:DYNARRAY[] of CHAR;
LayerVis :INTEGER;
PROCEDURE DriveDialog(VAR item:LONGINT; data:LONGINT);
VAR
L1 : ARRAY [ 1..256 ] OF STRING;
i : INTEGER;
BEGIN
CASE item OF
SetupDialogC:BEGIN
SetField(3,'Enter Name');
BEGIN
Layerhd := FLayer;
i := 1;
WHILE Layerhd <> NIL DO
BEGIN
L1 := GetLName(Layerhd);
i := i + 1;
Layerhd := NextObj (Layerhd );
END;
END;
END; {end dialog init}
SetdownDialogC:BEGIN { dialog cleanup }
END;
3:BEGIN
newname:= GetField(3);
END;
END; {end CASE}
FOR i := 1 TO NumLayers DO
BEGIN
i := 1;
If ( GetField(3) = L1 ) THEN
BEGIN
AlrtDialog('That name is already exists!');
SetField(3,'enter different name');
End;
i := i + 1;
End;
IF(GetField(3) ='') THEN { Checks for blank field }
BEGIN
AlrtDialog('Please enter a name!');
sysbeep;
END;
END;
BEGIN { Create Dialog }
ALLOCATE newname[1..29];
ALLOCATE startname[1..29];
dlogID := CreateLayout ('Create Name', TRUE, 'Ok', 'Cancel');
CreateGroupBox( dlogID, 13,'Layer & Sheet Name', TRUE);
SetFirstLayoutItem( dlogID, 13 );
CreateEditText( dlogID, 3, '', 29);
SetFirstGroupItem( dlogID, 13, 3);
SetHelpString( 3 , 'Enter a name for layer & sheet.');
SetHelpString( kOK, 'OK');
SetHelpString( kCancel, 'Cancel');
AlignItemEdge( dlogID, 5, 2, 30, 1);
AlignItemEdge( dlogID, 20, 2, 30, 1);
dialogOK := VerifyLayout( dlogID);
IF dialogOK THEN { Check Dialog is Good }
BEGIN
dialogResult := RunLayoutDialog( dlogID, DriveDialog );
IF dialogResult = 1 THEN
BEGIN
VSave('Temp Sheet');
TempLayerName:= GetLName(ActLayer);
Layerhd := FLayer;
BEGIN
LayerName:= GetLName(Layerhd);
Layer ( LayerName );
If LayerName = 'Page Border' THEN
ShowLayer
ELSE
HideLayer;
END;
Layer ( newname );
SaveSheet( newname , False , False, True );
HideLayer;
VRestore('Temp Sheet');
VDelete('Temp Sheet');
END;
END;
END;
RUN ( Createlayersheet );
[ 10-16-2003, 11:12 PM: Message edited by: Fuge ]
Thank-you very much for the help. It turns out that I found a much simplier way to do what I was trying to do. I used this amazing function dialogint. I then converted the number to a string and updated the field. I would never have looked at that command had you not posted your help. That dialog somehow has the ability to take input and then exit with a return. *shrug* My question now is how do I take my script that works great when I double click it on my custom palette, but won't work when I try to create a tool or menu command. What is the difference between a script created on the resource palette, and one cut and pasted (same one) into a tool or menu command on the plug-in editor. I have Vectorworks 9.02 until the funding comes through. Any ideas. Thanks again for the help.
As I understand it (which may or may not be accurate) a script can't be run by simply selecting a tool icon...it requires some interaction with the drawing. It's a tool for drawing.
A script like yours that gets it's input only from a dialog should be a menu command. You can assign a key short-cut to it so that no mousing is needed. Hit the key combo, enter the info and hit return or enter (on mac anyway).
I have a few such commands. They were simply copied and pasted as you describe, and they behave exactly as they did when they were run from the script palette. You do have some other options to explore in plug-in editor under properties.
As to the funcionality of the return key/ok button, I think it's supposed to be automatic with a button who's ID is 1. On mac, this button will also get the familiar look that all "OK" buttons have in all programs. So I guess it's an operating systems thing. Or maybe it's built into DialogEvent(). I think it's beyond our control in v-script.
Why your first script didn't work right is beyond me. What's your platform?
In any case, you may want to look at "Dialog Builder" under the "tools" section of the v-script area of the main site:
http://www.nemetschek.net/support/custom/vscript/vstool.html
This has always served me well and creates cross-platform dialogs that work the way I want them to whether they're run as simple scripts,tools,or menu commands. It does create a script with a rather different structure than your first one. Maybe the answer is somewhere in this dif.
[ 10-19-2003, 02:23 PM: Message edited by: ccroft ]
