justin1974 Posted August 26, 2003 Share Posted August 26, 2003 I've created the dialog fine but: How do i add chioces to the menu? Is there a way of making a reference file that contians the choices for the pulldownmenu? Quote Link to comment
tom_shady Posted March 11, 2006 Share Posted March 11, 2006 i found out the following: the pulldownmenuitems are created wenn the dialog is called with RunLayoutDialog(dialogId,drivedialog) drivedialog is your procedure, getting called while the dialog is displayed to the user Procedure drivedialog(item:Longint;data:Longint); RunLayoutDialog will pass item to drivedialog the first time drivedialog is called it will get the value SetupDialogC - this function isn?t documented ;-{ within this call you can create the pulldownitems with InsertCoice() a example is given here: http://www.nemetschek.net/support/custom/vscript/example.php have a look at Align Selected Object hope this will help, even if this discussion is quite old... well google find?s this page first, seems there aren?t so many modern-dialog programmers... Tom Quote Link to comment
