Jason33 Posted July 14, 2003 Share Posted July 14, 2003 Hello All, I am working on a script/commnd which uses SetOrigin. When I use it in a document script the rulers reset to the appropriate values. However, when I use it in a menu command the rulers do not reset. In both cases all the coordinates are correct with respect to the new origin, but I'd like to see the rulers reset after the menu command. Here is an example of what I'm talking about: Procedure SO; VAR mx,my:REAL; BEGIN GetPt(mx,my); SetOrigin(mx,my); END; RUN(SO): This works as a document script, but not as a menu command. Thanks In Advance, -Jason Quote Link to comment
