justin1974 Posted March 30, 2003 Share Posted March 30, 2003 How do you add thicknes to a simple roof? PROCEDURE ??BeginRoof (p1X:REAL;p1Y:REAL; p2X:REAL;p2Y:REAL; upslopeX:REAL;upslopeY:REAL; riseDistance:REAL;runDistance:REAL; miter:INTEGER; vertPart:REAL) ; Nothing about thickness?. Does not work inside BeginXtrd; Quote Link to comment
Guest Posted May 24, 2003 Share Posted May 24, 2003 I'm not sure if this will work for you, but there is a CreateRoof function with a thickness argument. Also, you could try calling SetObjectVariableReal(roofHandle, 170, theThickness); with selector of 170 to set the thickness of a "slab" object. See the VS Function reference Appendix G - "Object Selectors"...specifically the table for "Roofs, Floors, Columns". Hope this helps, Jeff Quote Link to comment
