Working with vectors...
Paolo
I'm using vector data type for my studies on a 3D tree generation tool I already published, as a first release, at www.VectorDepot.com, plugins section.
What I need is a function to rotate vectors in 3D space (same as the Rotate3D for 3D objects).
Example:
code:
Function Vec3DRot(v: Vector; XRot, YRot, ZRot: Real):Vector;
[/code]
I do not know if VW10 has something like this on the vector data type function set, I'm using VW9.5 that has a poor set of functions about vectors.
Thank you in advance for help. [smile]
Paolo,
Can you describe how you want your function to work? In my limited understanding of 3D vector math, I do know that the order of rotations affects the orientation of the result. For example,
rotate X 90?, rotate Y 90?, rotate Z 90?
yields a different result than,
rotate Y 90?, rotate Z 90?, rotate X 90?.
In the case of the VS command, Rotate3D, the axes are rotated in XYZ order.
Raymond
Paolo,
After overthinking the problem a bit, I finally realized it wasn't all that complicated. Here is my distilled version:
code:
function VecRot3D(V :Vector; RotX, RotY, RotZ :Real) :Vector;
{ Rotate a 3D vector by the amount specified in each axis. Rotation is in degrees. }
{ 14 February 2003 - Raymond Mullin }
Var
U :Vector;
procedure PartialRot(var X, Y :Real; Ang :Real);
var
W : Vector;
Begin
W[1] := X;
W[2] := Y;
W[3] := 0;
W := Ang2Vec(Vec2Ang(W)+Ang, Norm(W));
X := W[1];
Y := W[2];
End; { PartialRot }
Begin
U := V;
PartialRot(U[2], U[3], RotX);
PartialRot(U[3], U[1], RotY);
PartialRot(U[1], U[2], RotZ);
VecRot3D := U;
End; { VecRot3D }
[/code]
Best wishes,
Raymond
Thank you Raymond, I solved the problem also using matrices. Thanks to Dr. Math
http://mathforum.org/dr.math/
Description:
Given a vector and the three rotation angles (on x, y, z), the result is a new vector corresponding to the first vector rotated.
The resulting function is as follows:
code:
function Vec3DRot(v1:Vector;xRot,yRot,zRot:real):vector;
var
m : array[1..3,1..3] of real; {matrice of transformation}
c,s : real; {cosine and sine variables}
vt,v2 : vector; {temporary vectors used in calculations}
begin
vt := v1;
{********** X rotation **********}
c := cos(deg2rad(xRot));
s := sin(deg2rad(xRot));
m[1,1] := 1; m[2,1] := 0; m[3,1] := 0;
m[1,2] := 0; m[2,2] := c; m[3,2] :=-s;
m[1,3] := 0; m[2,3] := s; m[3,3] := c;
{rotation}
v2.x := vt.x * m[1,1] + vt.y * m[2,1] + vt.z * m[3,1];
v2.y := vt.x * m[1,2] + vt.y * m[2,2] + vt.z * m[3,2];
v2.z := vt.x * m[1,3] + vt.y * m[2,3] + vt.z * m[3,3];
vt := v2;
{********** Y rotation **********}
c := cos(deg2rad(yRot));
s := sin(deg2rad(yRot));
m[1,1] := c; m[2,1] := 0; m[3,1] := s;
m[1,2] := 0; m[2,2] := 1; m[3,2] := 0;
m[1,3] :=-s; m[2,3] := 0; m[3,3] := c;
{rotation}
vt := v2;
{********** Z rotation **********}
c := cos(deg2rad(zRot));
s := sin(deg2rad(zRot));
m[1,1] := c; m[2,1] :=-s; m[3,1] := 0;
m[1,2] := s; m[2,2] := c; m[3,2] := 0;
m[1,3] := 0; m[2,3] := 0; m[3,3] := 1;
{rotation}
Vec3DRot := v2; {the resulting vector}
end;
[/code]
