problem with Rotate3D command
Steve Cox
hello,
I'm not sure why it's not working. here is a small script which is working on my machine. you may need to give the rotate command before the duplicate, so there is no confusion as to what object is to be rotated.
PROCEDURE Rotate;
BEGIN
Beginxtrd(0,1);
Rect(0,2,2,0);
EndXtrd;
Rotate3d(-90,0,0);
Duplicate(2,2);
END;
RUN(Rotate);
i hope THIS helps.
-jason
Jason, thanks for that. I tried your script, and after a lot of tweaking came up with this one.
PROCEDURE Rotate3;
BEGIN
Beginxtrd(0,6); {draw shape}
Rect(0,0,2,1);
EndXtrd;
Duplicate(6,0);
Rotate3d(-90,0,0);
Duplicate(6,0);
Rotate3d(0,0,90);
END;
RUN(Rotate3);
This seems to always rotate the first shape, but duplicates the duplicate, so I think I am not selecting the right object to rotate. When I work out how to do that I may have got it sorted.
Then I tried this, to duplicate and rotate the selected object in the drawing.
PROCEDURE Rotate4;
BEGIN
Duplicate(6,0);
Rotate3d(-90,0,0);
Duplicate(6,0);
Rotate3d(0,0,90);
END;
RUN(Rotate4);
This doesn't rotate any shape, but duplicates the original OK
All I was trying to do was generate 3rd angle views of an object in my drawing. Perhaps as a non-programmer I should have stuck to the simple method. :-)
Steve
hello steve,
here's the deal. the Rotate3D works on the last created object, and the Duplicate works on all selected objects. to make matters more complicated, the computer does not recognize duplicated objects as new objects. here's a script that i think will solve your problem.
PROCEDURE Rotate5;
VAR
h:HANDLE;
BEGIN
BeginXtrd(0,1);
Rect(0,2,2,0);
EndXtrd;
h:=LnewObj;
Rotate3D(45,0,0);
{Rotate 1st then duplicate then rotate back}
Duplicate(4,0);
Rotate3D(-45,0,0);
{the following allows the process to be repeated without the above duplicate being duplicated again.}
DSelectall;
SetSelect(h);
{Second Duplication}
Rotate3D(0,-45,0);
Duplicate(-4,0);
Rotate3D(0,-45,0);
DSelectall;
SetSelect(h);
{repeat if needed}
END;
RUN(Rotate5);
I hope this helps.
-jason
