E&S - Shaun Posted July 23, 2002 Share Posted July 23, 2002 Here is a little and annoying bug that I have found. If I have a lighting symbol focused to a focus point and then I mirror the fixture (to allow the legend to fit) the beam angle and the field angle go off in different directions. The field angle is still on the focus point. The beam angle is going in the exact opposite direction. Is this something that others are finding? Is there a fix for this? G4 - 10.1.5 - VW 9.5.2 Quote Link to comment
Jon Harper Posted September 9, 2005 Share Posted September 9, 2005 Instead of mirroring the instrument, use the "Rot:" field in the object info palette and type "+180" after the degree that is there, or just manually enter the angle of the direction you want the light to be pointing in. Quote Link to comment
