how do you add an item to a pull down menu?
I'm trying to create a pull down menu. I can create the menu and the pull down box but I can't seem to figure out how to add items into the list. Anyone know how to do this? The guide does a pretty poor job explaining.
In your event routine, do something like this:
IF item = SetupDialogC THEN
BEGIN
InsertChoice( kPullDown, 0, 'choice 0');
InsertChoice( kPullDown, 1, 'choice 1');
InsertChoice( kPullDown, 2, 'choice 2');
InsertChoice( kPullDown, 3, 'choice 3');
InsertChoice( kPullDown, 4, 'choice 4');
num := 1;
SelChoice( kPullDown, num, true);
END;
Now that I have my choices in the drop down menu how do I get the menu to stay up. For some reason as soon as I select an item from the drop down menu the whole dialog box exits like I hit the OK button.
{$STRICT 10}
{$NAMES 10}
procedure main;
var pulldown1, pulldown2 : longint;
dialog1, dialog2, dialog1_button, dialog2_button : longint;
procedure HandleEvents( var item: longint; data : longint );
var test : longint;
begin
BEGIN
InsertChoice(pulldown1, 1,'Mesh');
InsertChoice(pulldown1, 2,'Solid Vynil');
SelChoice( pulldown1, 1, true);
END;
if (item = 1) then
begin
setbelowitem(dialog2,pulldown1,pulldown2,0,0);
InsertChoice(pulldown2, 1, 'Black Mesh -- 61"');
InsertChoice(pulldown2, 2, 'Black Mesh -- 73" w/ centerline');
InsertChoice(pulldown2, 3, 'Black Mesh -- 73" no centerline');
InsertChoice(pulldown2, 4, 'Blue Mesh -- 61"');
InsertChoice(pulldown2, 5, 'Blue Mesh -- 73"');
InsertChoice(pulldown2, 6, 'Green Mesh -- 49"');
InsertChoice(pulldown2, 7, 'Green Mesh -- 55"');
InsertChoice(pulldown2, 8, 'Green Mesh -- 61"');
InsertChoice(pulldown2, 9, 'Green Mesh -- 67"');
InsertChoice(pulldown2, 10, 'Green Mesh -- 73" w/ centerline');
InsertChoice(pulldown2, 11, 'Green Mesh -- 73" no centerline');
InsertChoice(pulldown2, 12, 'Trampoline(Black) -- 61"');
InsertChoice(pulldown2, 13, 'Trampoline(Black) -- 73" no centerline');
end;
if ( item = 2 ) then
begin
InsertChoice(pulldown2, 14, 'Green 72"');
end;
end;
begin
dialog1 := createlayout('Save File?',FALSE,'Exit','Continue');
createstatictext(dialog1,1,'This operation can not be undone so it is recommended that',-1);
createstatictext(dialog1,2,'you EXIT and then save this file before you continue.',-1);
setfirstlayoutitem(dialog1,1);
setbelowitem(dialog1,1,2,0,0);
dialog1_button := runlayoutdialog(dialog1,nil);
dialog2 := createlayout('Choose a material type.',FALSE,'Exit','OK');
CreateStaticText(dialog2,1,'Choose a material type:',-1);
pulldown1 := 2;
pulldown2 := 3;
CreatePullDownMenu(dialog2,pulldown1,32);
CreatePullDownMenu(dialog2,pulldown2,32);
setfirstlayoutitem(dialog2,1);
setbelowitem(dialog2,1,pulldown1,0,0);
dialog2_button := runlayoutdialog(dialog2,HandleEvents);
if ( dialog2_button = 1 ) then
begin
end;
end;
run(main);
