Katerina Posted January 21, 2003 Share Posted January 21, 2003 The esc key will cancel a command, -but- it will cancel at the point of where the script has read, and not the script entirely. -therefore, if preferences are being set in a script in the first lines, the new change of preference remains, because the procedure was before the point of hitting the ESC key. I discovered this when I had an offset duplicate question., earlier today I wish the esc key will cancel the entire script, from the first procedure. (posted wish list item, I was told to also post here) Quote Link to comment
ccroft Posted January 22, 2003 Share Posted January 22, 2003 I'm able to undo a either a whole or stopped script. Does this not work for you? Quote Link to comment
Katerina Posted January 22, 2003 Author Share Posted January 22, 2003 {I am able to stop a script with esc or by running another script. but : A script will run and read each line. If esc or other command is selected while the script is running, the lines that were already read sticks. You'll see what I mean by trying this test. Cancel out of this command before drawing a rect. p.s. this isn't a command I would use, just a test} Procedure test; VAR p:boolean; BEGIN DSelectAll; p:=GetPref(9); If (p=false) then begin SetPref(9,true); end; If (p=true) then begin SetPref(9,false); end; {cancel command before it reads the following text, you will see the preference set above sticks} SetTool(-203); end; RUN (test); Quote Link to comment
ccroft Posted January 23, 2003 Share Posted January 23, 2003 In my experience you are right. The actions done by a script up to the point of escape will stick, but those actions can be undone with command+z or by choosing undo from edit menu. I tried your test and it did change "zoom line". But if I undo the script the pref isn't changed. Or more precisely it is changed and then changed back. I guess this is more along the lines of a work-around. Some of my scripts can take a long time to execute on a large file and sometimes I run one prematurely. I cancel the script and then use "undo" to return the file to the state it was in before I ran the script. Quote Link to comment
Katerina Posted January 23, 2003 Author Share Posted January 23, 2003 OK, I will work around. Thank you. Quote Link to comment
