The ESC Key - glitch with scripts
Katerina
The esc key will cancel a command,
-but-
it will cancel at the point of where the script has read, and not the script entirely.
-therefore, if preferences are being set in a script in the first lines, the new change of preference remains, because the procedure was before the point of hitting the ESC key.
I discovered this when I had an offset duplicate question., earlier today
I wish the esc key will cancel the entire script, from the first procedure. (posted wish list item, I was told to also post here)
{I am able to stop a script with esc or by running another script.
but :
A script will run and read each line.
If esc or other command is selected while the script is running,
the lines that were already read sticks.
You'll see what I mean by trying this test.
Cancel out of this command before drawing a rect.
p.s.
this isn't a command I would use, just a test}
Procedure test;
VAR
p:boolean;
BEGIN
DSelectAll;
p:=GetPref(9);
If (p=false) then begin
SetPref(9,true);
end;
If (p=true) then begin
SetPref(9,false);
end;
{cancel command before it reads the following text,
you will see the preference set above sticks}
SetTool(-203);
end;
RUN (test);
In my experience you are right. The actions done by a script up to the point of escape will stick, but those actions can be undone with command+z or by choosing undo from edit menu.
I tried your test and it did change "zoom line". But if I undo the script the pref isn't changed. Or more precisely it is changed and then changed back.
I guess this is more along the lines of a work-around.
Some of my scripts can take a long time to execute on a large file and sometimes I run one prematurely. I cancel the script and then use "undo" to return the file to the state it was in before I ran the script.
