losing the handle after clip surface..
joiner
Jason,
Getting a handle to a clipped object does work the way you would think it does, although it seems it should.
Here's an example of how it can be done.
Fuge [Wink]
{--------------------- VectorScript ---------------------------}
Procedure ClipObject;
BEGIN
{ * Original Rectangle * }
Rect(2",1",-2",-1");
{* First Rectangle/ Hole *}
Rect(1/4",1/4",-1/4",-1/4");
ClipSurface(PrevSObj(LSActLayer),LSActLayer);
DelObject(LSActLayer);
{* Second Rectangle/ Hole *}
Rect(-3/4",1/4",-1 1/4",-1/4");
{* Third Rectangle/ Hole *}
Rect(3/4",1/4",1 1/4",-1/4");
END;
RUN (ClipObject);
  • 2 weeks later...
Fuge,
thank you for your time and interest. I should have been more specific with my problem. what i'd like to be able to do is:
PROCEDURE Notcher;
VAR
hl,hr,hn:HANDLE;
BEGIN
Rect(0,2,2,0); {*first rectangle*}
h1:=lnewobj;
Rect(3,2,5,0); {*SECOND rectangle*}
hr:=lnewobj;
Rect(1.5,2,3.5,1.5); {*Clipper*}
hn:=lnewobj;
clipsurface(h1,hn);
clipsurface(hr,hn);
Rect(1.5,1,3.5,0); {*next clipper*}
hn:=lnewobj;
clipsurface(hl,hn);
here depending on which system i use it either crashes all the way out of vectorworks, or ignores the command. the reason i want to do it this way is the above structure works perfectly in 3d using subtractsolid as long as long as the "clippers" are redrawn after subtraction. I was hoping to insert the 2d operations in with the 3d, and be done!! oh well! i'm 80% done with the 2d cutting using a structure that looks a lot like yours.
thanks,
-jason
Jason,
You can get the handle to the new surface with a little finesse. Since it is not obvious where the new object is in the active layer, it is necessary to count the position (N) of the pre-clipped object, and then reassign the handle to the Nth object after clipping.
The procedure KlipSurface, in the modified code below, can be used in place of ClipSurface. For tidiness sake, I also added a boolean to the call to delete the clipping object, if so desired.
It is assumed that H1 points to an object on the active layer for this procedure to work. If H1 points to an object on another layer, or H1 is NIL, it should do nothing. I hope this helps.
Raymond
PROCEDURE Notcher;
VAR
hl, hr, hn :HANDLE;
Procedure KlipSurface(var H1, H2 :Handle; DelTrimObj :Boolean);
{ Clip surface of object pointed to by H1, by object pointed to by H2. }
{ Return a handle to the new surface in H1. If DelTrimObj is true, }
{ then delete the trimming object. }
Var
I, J :Integer;
TmpHnd :Handle;
Begin
{ Find position of handle H1 in the stacking order. }
I := 0;
TmpHnd := LActLayer;
while (TmpHnd<>H1) & (TmpHnd<>nil) do
begin
I := I + 1;
TmpHnd := PrevObj(TmpHnd);
end; { while }
if (TmpHnd<>nil) then
begin
clipsurface(H1, H2);
{ Recover handle H1 }
H1 := LActLayer;
for J := 1 to I do
H1 := PrevObj(H1);
{ Delete trimming object? }
if DelTrimObj then
DelObject(H2);
end; { if (TmpHnd<>nil) }
End; { KlipSurface }
BEGIN
Rect(0, 2, 2, 0); {*first rectangle*}
hl := lnewobj;
Rect(3, 2, 5, 0); {*SECOND rectangle*}
hr := lnewobj;
Rect(1.5, 2, 3.5, 1.5); {*Clipper*}
hn := lnewobj;
KlipSurface(hr, hn, False);
KlipSurface(hl, hn, True);
Rect(1.5, 1, 3.5, 0); {*next clipper*}
hn := lnewobj;
KlipSurface(hl, hn, False);
KlipSurface(hr, hn, True);
END;
Run(Notcher);
For even tighter code, the calling procs can be written like this,
KlipSurface(hl, lnewobj, False);
KlipSurface(hr, lnewobj, True);
if procedure KlipSurface is defined like this,
Procedure KlipSurface(var H1 :Handle; H2 :Handle; DelTrimObj :Boolean);
HOWEVER, the first way of defining KlipSurface is safer.
BECAUSE, if procedure KlipSurface (defined the second way) is called with two user defined handle variables AND DelTrimObj is set to TRUE, then the object referenced by H2 gets deleted, and H2 is set to NIL, but the NIL value is not passed back to the calling procedure. So,
hn := lnewobj;
will result in 'hn' being defined incorrectly after the call.
If you are careful in your programming skills, then the shorter code looks and reads better, just be careful of the side effects. Happy New Year.
HTH,
Raymond
  • 1 month later...
To Raymond, Fuge and any other interested party.
upon further review I found that the above procedure does not work in a PIO script, as a "deep" traverse is required to recognize the components of the PIO. I came up with the following which seems to work in all situations.
FUNCTION Clip(ha,hb:HANDLE):HANDLE;
VAR h1:HANDLE;
holder,holder2 :STRING;
PROCEDURE Klip(clipped,clipper:HANDLE);
BEGIN
holder:=GetClass(Clipped);
holder2:=ActiveClass;
SetClass(Clipped,'Temp');
ClipSurface(clipped,clipper);
END;
FUNCTION Recover:HANDLE;
FUNCTION Finder(h:HANDLE):BOOLEAN;
BEGIN
IF GetClass(h)='Temp' THEN h1:=h;
SetClass(h1,'None');
END;
BEGIN
ForEachObjectInLayer(Finder,2,2,0);
setclass(h1,holder);
Recover:=h1;
END;
BEGIN
NameClass('Temp');
Klip(ha,hb);
Clip:=Recover;
DelClass('Temp');
NameClass(holder2);
END;
Thanks for your help, as your ideas lead to the final solution.
-jason
