Pink locus points are appearing on each symbol
NikitaA
3 answers to this question
If you create a new, blank file, and create a new symbol, does it display the pink X's?
If yes, see if the issue resides in your Vectorworks User Data and Preferences Folder by applying the 'Resetting Vectorworks Preferences' process. This process sets aside all your customisations, to see if they cause the issue. If the issue does not persist after executing this process, then something in your Vectorworks User Folder is causing the issue. If it does —when in a new, blank file, then something else is cause. Perhaps the driver of your dedicated graphics card needs to be updated or clean installed.
Please report back if this process resolves the matter:
Here's the process to apply:
