Johan Posted November 7, 2002 Share Posted November 7, 2002 Hello, Actually, i'm writting a plug-in for a concrete girder to be inserted in walls( walls with or without cavitys). The plug-in works well but i would like to initialize the parameters for the wall-assembly of the plug-in before the girder is created by selecting the wall before calling the plug-in. Gathering the wall-definition is no problem. Someone told me i have to split up the script in : - gathering the wallparameters( of the selected wall), - initializing the parametes of the girder plug-in( -> the parameters of the wall : determines the girder width and his position in the wall) - calling the plug-in. My problem is the initializing of the parameters and calling the plug-in from within the script(and with a normal behaviour). Thanks a lot for any response. Johan Quote Link to comment
Alexandre Villares Posted November 8, 2002 Share Posted November 8, 2002 I guess you could make a script that reads the selected wall info and sets the parameter defaults of your Plug-in Object using this: SetRField(GetObject('plug-in-object-name'), 'plug-in-object-name', 'parameter-name', 'value-as-string'); But note that a VS tool that has it's own parameters is unable to place a plug-in object. [ 11-07-2002, 09:15 PM: Message edited by: Alexandre B A Villares ] Quote Link to comment
Johan Posted November 10, 2002 Author Share Posted November 10, 2002 Thanks for your help. I works great. Johan Quote Link to comment
