Get3DCntr - Not true center
rl
Get3DCntr takes top height-bottom height and uses the result as center. False. Ex: Draw a wall with 16' top z, 4' bottom z, returns 12' as center. 10' should be center. 10'+6'=16', 10'-6'=4'. Is there a work around? Much to my dismay WallHeight returns top of wall at top left and top right corners. How do you obtain the bottom z of a wall in VS without resorting to object info and manually entering the info?
Help!
rl
To get true center of object, or in my case walls, this is what you do. Draw a wall, set its heights (bot z, top z).
Use Get3DCntr(h,px,py,zvalue);, Use WallHeight(h,startHt,endHt);or Hheight()or Get3DInfo(). Use z value(center)from Get3DCntr - wall height/2 from WallHeight() or others mentioned. That will give you bottom z. Now that you have bottom z of wall, take wall height/2 + bottom z/2 = true center.
rl
