bill steer Posted August 15, 2002 Share Posted August 15, 2002 HI, can you recomend someone that is fluent in Vectorworks script ? We might want to create some metal box drawings using script to calculate various dims, and hardware. We use a different cad program but are slowly transitioning to vectorworks. thanks, bill steerPico Metal Productswww.panelboard.com Quote Link to comment
bill steer Posted August 15, 2002 Author Share Posted August 15, 2002 Forgot to say we are in Santa Fe Springs, Ca, Just a bit south of Los angeles Quote Link to comment
Peter Huggins Posted August 16, 2002 Share Posted August 16, 2002 Hi Bill, I sent you a private response "off-list". If you do not receive it, I will try and contact you by telephone. Peter Huggins. Quote Link to comment
Don_dup2 Posted August 16, 2002 Share Posted August 16, 2002 quote: Originally posted by bill steer: HI, can you recomend someone that is fluent in Vectorworks script ?We might want to create some metal box drawings using script to calculate various dims, and hardware. We use a different cad program but are slowly transitioning to vectorworks. thanks, bill steerPico Metal Products www.panelboard.com Quote Link to comment
Don_dup2 Posted August 16, 2002 Share Posted August 16, 2002 Please excuse my previous post. I hit the wrong key. What I wanted to say was, can you see a way to use VW for sheet metal design. At present I use an obsolete pc program (Metalman) and DXF it into VW. It takes care of the bend allowances, but you can only work with one part at a time. When it gets into VW, you can't render it because it isn't a surface just a wire frame. It would be great if VW could be used for sheet metal. Don Quote Link to comment
