arthur&l?on Posted July 26, 2002 Share Posted July 26, 2002 Hello, Could someone give me some hints on how to use resedit on mac to create *.rsr picture files to use in dialogs. I'm scripting on windows and have no idea on what is really this resedit. Thanks for your help. Francesco Quote Link to comment
TiTaNiuM sAMuRai Posted July 26, 2002 Share Posted July 26, 2002 I don't know if ResEdit will edit icons itself, but I can tell you it's an editor of a mac file's header information. If you don't already know, a mac file has two sorta-parallel parts (forks). The Resource fork contains all the non-data information, including icons. You can paste from the clipboard to the icon window, but I'm not sure you can edit that image within RE. Quote Link to comment
Fuge Posted July 26, 2002 Share Posted July 26, 2002 To Create a Windows Resource image using Resedit on Mac 1. Open Resedit and create a new resource file from the "File" Menu - "New..." name your file with a .rsr extension.2. Create a picture resource in your resource file by going to the "Resource" menu - "Create New Resource" When the dialog box appears choose "PICT from the list or type "PICT" in the text box hit OK.3. Copy and paste a pict picture into the for most window that appears.4. Note the title of the window, should be something like PICT ID= 128 from your file name. Keep track of the number this pict resource is. That number is the number used byCreateControl(lEditID,5,1,'SplashImage',128);5. Close all the windows and save your file.6. Transfer your file to a PC using the same technique as with workspace files. See Tech Note:http://www.nemetschek.net/support/technotes/025.htmlAlso check the Vectorscript exampleAlign Selected Objects here:http://www.nemetschek.net/support/custom/vscript/example.html HTHFuge [ 07-26-2002: Message edited by: Fuge ] Quote Link to comment
arthur&l?on Posted July 27, 2002 Author Share Posted July 27, 2002 Many thanks to both of you. Francesco Quote Link to comment
Guest Posted August 21, 2002 Share Posted August 21, 2002 You can download ResEdit from Apple's website for free:http://developer.apple.com/tools/ResEdit213.hqx You can also purchase a resource editing tool called Resourcerer here: http://www.mathemaesthetics.com/ResorcererInfo.html Quote Link to comment
